Old August 25, 2012, 06:02 AM
Dzzope's Avatar
Good more budget option IF you have trim support.. If you don't then your best sticking to the M4..
Old August 25, 2012, 06:30 AM
what is trim support?
Old August 25, 2012, 07:46 AM
Dzzope's Avatar
Trim is a command that the OS sends to the SSD in order to do garbage collection and keep the drive running fast..
you will need to post your motherboard model or google it and see if it is capable of supporting trim.
If it doesn't support trim you will want to get a drive that doesn't need it.. Like the M4 (probably one of the best price to performance drives available too)
Old August 25, 2012, 12:48 PM
model: jetway HA12-LF.
Old August 25, 2012, 03:33 PM
Dzzope's Avatar
Not had much time looking but I can't see that it does support trim.. looks like the M4 would be much better option (unless I've missed something from my skim of the specs)
Old August 25, 2012, 04:16 PM
Question
sorry M4?
Old August 26, 2012, 06:49 PM
Dzzope's Avatar
Crucial M4 SSD..
Need advice on upgrading AbC-50 New Builds 8 August 23, 2012 02:05 PM
Upgrading advice CurEuS Video Cards 11 February 16, 2012 05:06 PM
Need help with my system and upgrading information. Kinslayer New Builds 25 July 9, 2011 04:50 PM
Upgrading to SB. Need some advice please. ern88 New Builds 17 March 18, 2011 05:53 AM
Upgrading low end system Simfriend Video Cards 8 March 21, 2010 02:06 PM
