  #21 (permalink)
Old August 22, 2012, 08:59 PM
What resolution of monitor do you plan to use with this setup?
  #22 (permalink)
Old August 25, 2012, 05:12 PM
2560x1440
or a triple monitor
  #23 (permalink)
Old September 4, 2012, 08:57 PM
IM STUCK! im not sure between a 670 or 680 or the p9x79 pro deluxe or rampage 4 extreme!
  #24 (permalink)
Old September 5, 2012, 01:31 AM
GT7R's Avatar
If you're gonna SLI then go for 670s but NON reference! Reference 680s are pretty decent.
  #25 (permalink)
Old September 5, 2012, 02:04 AM
i know I'm going for sli later but want to see if i need the extra card wouldnt want to spend another 400 500 dollars if i dont need it. mine as well just go for the 680a little better
  #26 (permalink)
Old September 5, 2012, 04:55 AM
Any reason your thinking of going with the P9X79 Deluxe vs saving a couple bucks and getting the P9X79 Pro, don't think there is much difference other than amount of USB 3 ports and BT 3.0 vs BT 2.0 or something.
  #27 (permalink)
Old September 5, 2012, 08:48 AM
yea i think its more of p9x79 pro vrs rampage 4 extreme its just such a hard choice
  #28 (permalink)
Old September 5, 2012, 09:32 AM
I guess your big question on that then would be will you ever run more than 2 GPU's, thats the main advantage of the Rampage 4 ex board. 4 GPUS at 16x where the X79 Pro only goes 2 GPU at 16x
  #29 (permalink)
Old September 5, 2012, 12:21 PM
If you have the budget, which it seems that you do, grab a GTX 680. In a few months you may decide to SLI, however a single 680 would be sufficient for most games at those resolutions right now. Grab the motherboard that you want, the Rampage IV Extreme is a very nice board, although there is nothing wrong with the Sabertooth, WS, or Deluxe models either. Watercooling can be a great hobby, but personally I'd recommend starting with a beefy air cooler, or an all-in-one.
  #30 (permalink)
Old September 5, 2012, 01:28 PM
7970 is MUCH better bang for buck at the moment and it handles higher resolutions better (generally) than the nvidias and overclocks like an animal..
BUT
I couldn't recommend going x-fire..
Pitty you can't try before you buy... 1 card I would say the 7970 for sure.. 2 cards 670's are the way to go(IMO)..
To max everything and still get good fps in high-end games you'll need dual cards really for either the 27" IPS or 3 1080 screens. (no matter what card you pick)
(obviously depending on the games and how much eye candy you like but from your choices then I'm guessing max settings and min fps as high as possible)
IMO the nvidia's are over-priced at the moment.. and are due a price-drop soon (or risk the same mistakes AMD did when the 680 was launched)
If you can.. hold out on buying as long as you can cos a 7970 is the same / lower price of a 670 at the mo and thats just not right..
To build, or not to build: that is the question Timid newbe New Builds 5 August 12, 2010 04:33 AM
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 01:48 PM
Critique my gaming build build 1080p New Builds 10 January 14, 2009 03:18 PM
