Old August 24, 2012, 05:25 PM
Checked out the BIOS, everything seems to be normal, checked voltage.. 1.5v for this ram. Also swapped the chips around, and went down to 2 chips at a time, all chips seem to be working fine. Not sure what else to do? :S
Old August 24, 2012, 05:44 PM
dandelioneater's Avatar
Perhaps try booting with only one stick of ram installed. Do it for each stick and see if one of the sticks is bad. Also, inspect the slots on the motherboard for any damage.
Old August 24, 2012, 06:20 PM
So I was in the AI bios settings and there was an option that said "Auto OC" I think, its desc said it ups the voltage of the CPU and ram to better increase performance, I hit okay and without even being able to save/exit the bios the computer restarted and all 16gb of ram are showing up now. I am not sure what it changed as I checked the Ram voltage and CPU-Z said its at 1.5 still.. Going to look around more to see what was the fix exactly.
Old August 25, 2012, 06:16 AM
So I still seem to be having issues, also getting random crashes where my screen goes blank and can't get it back :S.. Updated to the latest version of the BIOS, not sure what else to do.. Hope I don't need to RMA the motherboard.
Old August 26, 2012, 02:15 AM
Turns out I have submitted an RMA to Ncix for the board, any one know how long an RMA process takes to complete, don't want to be without a motherboard long
Finally finished the build....you thoughts? ginman522 New Builds 6 April 9, 2012 07:08 PM
Finished NZXT Phantom Build xhrrcollector Cases 11 January 4, 2011 10:20 PM
New half-finished build fails to boot. ImmaPC Troubleshooting 24 August 27, 2009 01:50 PM
Finally finished my I7 Build quikgp New Builds 11 August 12, 2009 07:07 AM
Just finished my 1st build Dogger1 New Builds 21 February 12, 2009 09:38 AM
