Old August 19, 2012, 08:27 AM
Default Need advice on upgrading
Currently, I'm running a 3 years old AM2+ setup with a gigabyte ma-790x ud4p motherboard and phenom 2 720be CPU. I am looking into getting my first SSD. But I did some research and found that my choices would be very limited with no trim support. :( so i came up with a couple of options:
  • buy new SSD only (probably a crucial m4)
  • upgrade motherboard, ram(am3+ with ddr3), and new SSD (vertex 4 maybe)
I use this computer a few hours a day, and occasionally play skyrim on it. My budget would be roughly $100 for SSD and additional $150 for ram and mb if necessary.
I'm unsure of the real world performance difference between the 2, and whether upgrading my motherboard and ram will justify its cost. Any input would be appreciated. Thanks.
Old August 19, 2012, 08:45 AM
sswilson's Avatar
If you're happy with the general performance of your current hardware and the only reason you'd be upgrading the motherboard would be for trim support, I'd suggest you look at newer SSDs with greatly improved non-trim idle maintenance features rather than upgrading your motherboard just for trim support. (AKG now includes non-trim results in his reviews.... ;) ).
Old August 19, 2012, 09:44 AM
techman95's Avatar
honestly if you want an ssd you need to get one that is at least 180GB or larger (say 256 or so ) because anything smaller will be filled up way to quickly and really not worth it unless you cache with it and only intel chip sets support caching. and for the board i would recommend a 990x or fx series board since they have the best support of trim and s.m.a.r.t, but dont get me wrong the 970 series boards will work just not as well as the 990 series of chipset, so if you really want to do an ssd you need to get a larger budget and really do some research. if you get the size you need and with the controller that suits you (sandforce, indilinx, or marvell) you will love having an ssd.
Amd....definitely a blond female.....not much on the cpu side, but always strutting about showing off her gpus
Old August 19, 2012, 01:26 PM
Hehe, you're right. I wasn't sold on buying a new motherboard just to get trim and sata3 either, since I won't be using most of the other features. I did look at the vertex 4 review on here, but its slower than the m4 under non-trim. Are their any other options out there around the $100 mark?
Old August 19, 2012, 01:33 PM
EmptyMellon's Avatar
Arrow
Crucial has a new line of SATA II drives, called Crucial V4 - Newegg.ca - Computer Hardware, Hard Drives, SSD, Internal SSD, Crucial, SATA II, and there are some 128GB SSD for $99.
Old August 19, 2012, 05:54 PM
hossdaddy's Avatar
have you tried to unlock and overclock that cpu? approx 70% of those cpu's will unlock and should overclock to approx. 3.2ghz or higher. This would represent a significant improvement for you and best of all its free!
Main System:
i5 3570k @ 4.6ghz | GA-Z77X-UD3H | Gigabyte GTX 670 | 8gb Redline 1600mhz | CM 690 | Logitech G9x | Mushkin Cronos 120gb ssd | Benq 24" | CM Hyper 212+ | Seasonic 750w | X-Fi Titanium | Sennheiser 350 | Razer blackwidow | Win 7 64-bit
Backup System:
AMD X2 7750 BE @ 3.0G | Asus M3A78-CM | 2x2gig 800mhz 4-4-4-12 | SB LIVE | Samsung 22" | Asus 9800gt | Antec NEO 620w | Logitech G5 | ThermalTake Matrix | Arctic Cooling Freezer 64
Old August 19, 2012, 08:08 PM
Drop in an M4 and be happy..
I would go 256GB with current prices if you have the funds to do it, gives you plenty of room for all your games and apps and leaves free space for the drive to work with to stay fast
(try not to fill an ssd..)
And like said above.. unlock and overclock..
Old August 23, 2012, 09:44 AM
Thanks for all the suggestions. Yes I do have the CPU unlocked and oc'ed. Looks like I'll be going with a M4. Thanks again.
Old August 23, 2012, 02:05 PM
hossdaddy's Avatar
what cpu cooler are you using? Have you installed a cpu temp monitoring program?
Main System:
Backup System:
Upgrading advice CurEuS Video Cards 11 February 16, 2012 04:06 PM
Upgrading from a GTX 460. SLI? Wait for 7xxx? Looking for advice! Bentech Video Cards 8 February 14, 2012 04:35 PM
Upgrading from 9800gt, would appreciate any/all advice Navi Video Cards 13 February 3, 2012 02:15 PM
Upgrading to SB. Need some advice please. ern88 New Builds 17 March 18, 2011 05:53 AM
Need some advice before upgrading my old ass computer Syrax Video Cards 28 April 7, 2010 05:24 PM
