Old August 14, 2012, 01:57 AM
Trial Member
Default Need Advice For First Time Build
Hi everyone, this is a first time build, i'm looking to use the computer mostly for school stuff and gaming. Just wondering is all the parts are compatible and if i have the ability to run dual screens.
-Intel Core i5-3570K
-OCZ OCZ-ZT750W ZT Series ATX Modular Power Supply - 750W, 80 Plus Bronze, 140mm Fan, Active PFC
-Samsung SH-222BB/BEBE 22X Internal DVDRW Driv3
-NZXT Phantom 410 Special Edition BLACK/WHITE Trim Crafted Mid Tower Case
-Corsair Vengeance Low Profile 8GB (2x4GB)
-ASUS P8Z77-M mATX LGA1155
-MSI GeForce GTX 560 Ti 448 Twin Frozr III
-Western Digital Caviar Blue 1TB
i was hoping to get the msi geforce gtx 560 ti from directcanada.com but it seems that they're unavailable now? if anyone has an suggestions for a better or equal video card, it would be greatly appreciated.
Old August 14, 2012, 03:23 AM
GT7R's Avatar
Your parts are compatible but:
1- What resolution will be your 2 monitors? If you're going to game on both, you better wait for at least 660Ti or get a 670. (although I don't know what your budget is and how much that 560 costs you).
2 - I'd stay away from that OCZ psu and go for a similarly priced, even if lower output rate but higher quality Seasonic, Antec or Corsair.
3 - I'd personally (for an unknown reason) had lots of bad experience with the last gen vengeance RAM, just pick up a good Kingston/G-Skill set instead.
4 - Good luck! :)
First time PC build Big Iron New Builds 9 December 19, 2010 04:08 PM
Need advice for a first time/extravagent WC setup. GT_Forthelulz Water Cooling 3 May 17, 2010 02:58 PM
First time water cooling, need advice. Blam Water Cooling 56 July 20, 2009 05:54 PM
Overclocked for the first time.. need some advice MrFoxx Video Cards 11 May 17, 2009 11:03 PM
First time build CGW Troubleshooting 10 September 12, 2007 07:27 PM
