Old August 13, 2012, 05:13 PM
MARSTG's Avatar
Default how about a LGA 2011 build?
I am flirting with the idea of getting a LGA 2011 build. I found some local core i7 3930k at 400$ or under and from newegg, from what I see I would like the ASUS P9X79 PRO or ASUS Rampage IV Gene but I am a bit scared, everybody is telling me this CPU is hot requiring high end air or water cooling. A Corsair H60 would cut it for this big boy? And for those wondering what am I going to use this rig : is F@H! Points wise would it be better to get a 2600k and a 2500k or these 2 together would equal the 3930k? I want to stop the dependency on GPU folding, is not good on the hydro bill!
Old August 13, 2012, 06:06 PM
dandelioneater's Avatar
For z68, a basic DDR3-1600 9-9-9-24 1.5V kit or tighter timings would be fine. I don't think that higher frequency would matter all that much for folding or gaming and certainly wouldn't be worth the extra money. Gskill ripjaws is usually pretty good stuff.
Old August 13, 2012, 10:32 PM
If you need low profile RAM, Corsair is a good choice.
Old August 14, 2012, 12:59 AM
As for the decision between the 500R & 400R it mainly comes down to $30 and that 200mm side panel fan that's included in the 500R. Dust filters are great, but they aren't a necessity on the top of the case and especially so when you have positive airflow.
Mr. Bean - Sexy and I Know it Arinoth Off Topic 1 January 24, 2012 08:11 AM
New Multi-GPU LGA1155 i7 Gaming/Video Editing Build El Topo New Builds 35 August 14, 2011 07:44 PM
Sexy B&W Custom PC build Mnpctech Off Topic 0 July 25, 2011 09:38 AM
sexy new 27' 1ms monitor Technokat Display Units 20 May 21, 2010 03:25 PM
Look at this sexy beast of a mobo! bojangles CPU's and Motherboards 20 August 21, 2008 06:44 PM
