Old August 7, 2012, 06:44 PM
Smile Opinion about my build.
So I decided to build computer. Here is its specification:
GPU: Gainward GTX670 (refere)
CPU: Intel i5-3570k
MOBO: Asrock Z77 extreme 4
I have HDD,Case and AC from my old computer. So what do you think about this set?
P.S: Sorry for my poor english ;)
Old August 7, 2012, 08:08 PM
Looks like a decent, well-balanced build. Those 3570k's are really nice, I just bought one myself for my HTPC, supposedly good overclocks too.
Old August 7, 2012, 10:52 PM
dandelioneater's Avatar
I'm sure it will be a good build, just make sure your power supply from the old pc is in good condition. Have you considered picking up an SSD and use the HDD for storage?
Old August 8, 2012, 01:31 AM
I am pretty sure that my old AC will be good becouse I bought it whit thinking abaut new computer it's OCZ600MXSP. I am going to by SSD, but not now. What are you thinking about this GPU?. Thanks for your opinion :)
Old August 8, 2012, 08:28 AM
SHiFT.'s Avatar
+1 on the Power supply.
Old August 9, 2012, 03:19 AM
Dzzope's Avatar
That PSU is far from the best but should be sufficient..
The GPU, I would swap for a Gigabyte windforce as they are reference prices but added performance and cooling.
What resolution are you playing at?
A 670 will max pretty much any game up to 1920x1200, so if your using smaller resolution than 1920x1080 you may be better going for something a little smaller.
Old August 14, 2012, 03:58 PM
I am playing at 1920x1080 :) 27 inch monitor so it must be something "big"
new build opinion please neo678123 New Builds 10 March 24, 2012 10:19 PM
New Build, need 2nd opinion. siklee New Builds 13 February 5, 2012 04:10 AM
Opinion on new build sonoflo96 New Builds 4 November 26, 2011 06:02 AM
Opinion on i7/GTX 285 build Tikal New Builds 10 February 3, 2009 12:33 PM
