Advice on build, 2560x1600 setup, $1500
The system is to drive a 3008WFP and a 2408WFP. The use will be multimedia/browsing, gaming, and some photoshop, any maybe 1 VM. I am not looking for crazy full eye candy, just playable 30 fps at 2560x1600. Since I am not a hardcore FPSer, so response time is not vital.
OCing ambition wise, reach 4.4GHz or so without the whole rig sound like a barnstorming cropduster. I may SLI at a later date, or have a second card used for PhysX or something like that (assuming if more titles actually use PhysX.) I originally think that 760W might be sufficient... anyways.
I want to hear if I should bother with Ivy or just hunt down some Sandy Bridge 2600K Z68 setup instead, since PCI-E 3.0 is really not important for now, and that mobo+cpu as it is takes 40% of the total system expense...
EDIT: I read in some sources where it's recommended to get the 4GB v. of GTX 670 given the resolution of the 30"er. Is that really something I should consider? If so, would I have a harder time hunting down a matching card to SLI with later down the road?
EDIT2: Is 256GB for SSD better off for me, or should I go with 128GB and spend the remainder on yet another HDD? I really can't make a call on this...
3770K
Sabertooth Z77
Corsair H100
GTX 670
*Xonar D2X (from old rig)
Corsair HX 850W
16GB 2x8GB 1600 DDR3, Ripjaw
Samsung 380 256GB as Boot drive
*1x 1TB WD Black (from old rig)
*1x 1TB WD Green (from old rig)
Corsair 600T white
