-   -   2nd-3rd-ish build. Need help and suggestions. (http://www.hardwarecanucks.com/forum/new-builds/55901-2nd-3rd-ish-build-need-help-suggestions.html)
melonpaste August 4, 2012 08:03 PM
Hi guys. My house got burglarized and they took my first-ever rig. I figured that I might as well build a better one and try out Nvidia this time.
HDD
Video card (GTX 680)
i5 3570K
RAM and mobo (bundle)
PSU (is it enough?)
Case looks promising but just in case
Dzzope August 4, 2012 08:30 PM
Don't use a green HDD.. or at least not for anything but storing data/media.. Don't use it for a boot drive or to run programs from..
If your not getting an SSD then I would suggest the Seagate 2TB 7200.14.. If you are getting one then a 256GB vertex4 is pretty sweet.
A 680 is overkill for your resolution.. 670 DC II wouldd be awesome though..
Can't say I'm a fan of gigabyte.. bad experiences with trying to return faulty stuff to them.. But they do good spec boards for the price.
PSU is a little more than you need.. 650 would be enough.
Again not a huge fan of antec cases but nothing wrong with them.. but personal preference is a huge thing with cases.
BryceBooth August 4, 2012 08:46 PM
Nice build there, nVidia recommends a minimum 550 Watt PSU for a single GTX 680, so that PSU should be sufficient even with a mild processor overclock. I would suggest looking at another hard drive however, perhaps a Caviar Black model, or other 7,200 RPM disk if you will be using it as your primary drive.
The Antec chassis will likely serve you well, you may want to add an additional intake fan, as it includes only two exhausts, and no intakes. Good-luck.
