Old August 3, 2012, 04:33 AM
Trial Member
Default Jumping into water cooling.
so ive had my rig for about 7 months now, ( i7 2700k, ausu max IV extreme z-68, 3 pny 1.5g gtx 580's, corsair ax 1200, corsair force gt 120 g ssd, 16 gigs g skill ripjaw 1866 ddr3) all in a haf 932 case. what im really kinda lost on is a few things actually. like 1 being the diffrence between " in series triple gpu water block connector, vs a parallel block. im gonna be running 3 blocks on the gpu as well as one for the cpu/ vrm/north bridge and southbridge chips ( with a full pom block made by mipps), and have future plans of cooling the ram.. but im wondering what kind of rads to use with my duel MCP655 swiftech pumps in a single loop. please let me know what you think and any advice is much appreciated.. :)
Old August 3, 2012, 07:48 AM
Pabz0r545's Avatar
It really depends on what you are after with your cooling. If you want silence you will want a thicker radiator with a lower fpi(fins per inch) and you can run fans at a really low speed like that. If not you can get a normal radiator and use really good fans like gentle typhoons or yate loons on it which high static pressure and higher RPM.
I think it is generally recommended to have 1 120mm radiator for each component being cooled. Personally I think it's safer to have a little more then that. So your CPU, 3 gpu's and the motherboard being cooled I would recommend at least 4x120mm worth of radiator. You might have to switch your case to fit all that water cooling. :)
Aquarium gear for water cooling??? WATER CHILLER??? clshades Water Cooling 6 March 15, 2012 09:21 PM
Water Cooling limpz LinusTechTips Q&A 3 February 13, 2012 09:04 AM
First water cooling set up.. metalcore New Builds 13 January 7, 2009 07:46 PM
SLI Water Cooling. BALISTX Water Cooling 5 March 19, 2008 10:02 AM
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
