Originally Posted by Card Hi Dzzope,
Huge favour - Could you put together that build at memory express and then email that configuration to me? That would be so great... because it's hard for me to pick out each of those items.
THanks.
Nick |
Corsair Graphite Series 600T Mid Tower, Special Edition White x1$169.99
Intel Core™ i5-3570K Processor, 3.40GHz w/ 6MB Cache x1$229.99
Corsair Hydro H60 High Performance CPU Cooler x1$74.99
Asus P8Z77-V PRO w/ Dual DDR3 1600, 7.1 Audio, Gigabit Lan, WiFi, SLI / 3-Way CrossFireX x1$219.99
Corsair Vengeance 8GB DDR3 1600MHz CL9 Dual Channel Kit (2 x 4GB) x1$54.99
OCZ Vertex 4 Series SATA III Solid State Drive, 256GB x1$214.99
Seagate 2TB Barracuda 7200rpm SATA III w/ 64MB Cache x1$109.99
Asus GTX670 DirectCU II TOP Geforce GTX 670 2GB PCI-E w/ Dual DVI, HDMI, DisplayPort x1$459.99
Corsair Enthusiast Series TX650M Modular Power Supply x1$109.99
Memory Express Assemble Hardware x1$40.00
Samsung SyncMaster S24A850DW 24in Widescreen LED LCD PLS x1$499.99
total 2200.. @ memoryexpress..
Unfortunately any link I would be able to give you for a build is dependant on the browser session..
If you have any trouble selecting the parts, I've heard of people phoning them and getting good service..
But I can't stress enough.. use their price-beat service (find out how it works and then go to it) to save yourself a good chunk of change. Someone above named a few sites you can use to find prices.
You need to price-match.. and if you spent some time I'm sure you could find a similar PSU at a real bargain price somewhere and again price-match it.. (psu is just an example.. same goes for most parts)
Case may not be to your liking but I chose that one as there are many very good cases in many different styles at that price point.. and I really like that one :P
The monitor is only 1 of a few different Options.. IPS or PLS from samsung..
Ideally I would suggest you go see 2 side-by-side (IPS and a standard 24") so that you will know yourself if it's worth the money to you.
