Old July 30, 2012, 07:40 AM
Default cooler master or corsair psu?
hi guys,
which one should i buy cm silent pro hybrid 850w or corsair ax750w?
thanks.
Old July 30, 2012, 07:43 AM
Soultribunal's Avatar
Although Coolermaster is slowly getting better, I still would not use there PSU units.
Get a Corsair.
-ST
www.realhardwarereviews.com
Old July 30, 2012, 08:03 AM
stoanee's Avatar
^^ ditto
heatware
Old July 30, 2012, 09:01 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
That CM (IIRC) is a "co-developed" unit made by Enhance. Its a good PSU. BUT that Corsair....is VERY sweet (when possible....I use Corsair AX'ers in all my builds). Its a (IIRC) Seasonic built beast. I personally would pick the Corsair, but both are good kit. :)
YMMV
Old July 30, 2012, 11:49 AM
YMMV
A lot of it now is Seventeam and other OEM makers. Enhance does there higher end stuff and normally is much better than what CM gets, but then again the OEM specs it to the Customer. Its why Silverstone Enhance = good, CM = Enhance = meh.
-ST
Old July 30, 2012, 01:43 PM
rfglass's Avatar
http://whirlpool.net.au/wiki/psu_manufacturers
Old July 30, 2012, 03:11 PM
Ravenor's Avatar
Definatly the Corsair. Very well build unit.
Roy: [singing] We don't need no education.
Moss: Yes you do; you've just used a double negative
Old July 30, 2012, 03:19 PM
Corsair ala Seasonic except for the 1200ax which is a darn fine power supply.
Could just cut out the middleman and buy seasonic though.
Old July 30, 2012, 04:24 PM
Sometimes yes, but a lot of times there are more incentives to buy one of there OEM labeled ones instead. That, and doing an RMA with Seasonic Direct was not nearly as pleasent as other companies.
To boot they have some stiff competition comming too from CWT and Superflower. Which makes looking at other brands more lucritive.
I would have suggest the HALE series or Rosewill's if they were easier to get. Good units.
-ST
Old August 1, 2012, 11:02 PM
thanks all, ill get a corsair psu. :)
Corsair 800D to Cooler Master Cosmos II? BADPhoenix Cases 1 February 6, 2012 01:15 PM
Cooler Master V8 and Corsair carbide 400r mardig88 Air Cooling 1 November 10, 2011 10:47 PM
Corsair CC600T or Cooler Master Haf X 942? proxy Cases 9 January 20, 2011 09:47 AM
[FS] Cooler Master HAF X (or trade for Corsair 700D) + other stuff Prolab Buy/Sell & Trade 5 September 2, 2010 09:33 PM
[WTB] Cooler Master Cosmos S, Corsair HX1000 futures Buy/Sell & Trade 1 May 14, 2009 12:46 PM
