Old July 22, 2012, 06:23 PM
Trial Member
Default Help With a Budget build please.
I am looking to build a Pc for playing the latest games at 1080p and also being able to video edit with ease for
a budget of 800 USD?
Suggestions for builds would be nice.
Old July 22, 2012, 07:43 PM
great_big_abyss's Avatar
Will you be overclocking? Reusing old parts (such as harddrive, case, DVD Drive, etc.).
Intel Core i5 3550 3.3GHz Quad Core Processor - $199.99
ASUS P8Z77-V lk ATX Motherboard - $109.99 (after MIR)
Kingston HyperX1600 2x4GB DDR3 RAM - $40.99
WD Caviar Black 1TB HDD - $109.99
Antec HCG-620M 80+Bronze 620W Powersupply - $69.99 (after MIR)
Bitfenix Shinobi Windowed Enclosure - white - $69.99
Gigabyte Geforce GTX560 Ti Core 448 - $199.99 (after MIR)
Total: $800.63
EDIT: This is in Canadian Dollars, btw. Depending on price variations, you may be able to bump up the CPU to a 3570K and add a cooler. I'm not sure what the price differences are, and quite frankly, since I'm Canadian, don't care enough to bother checking US prices as well. But prices should be fairly close!
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old July 22, 2012, 08:41 PM
^^^Nice choices. Personally I would swap the case as I am not a fan of white, but otherwise I suggest following the above.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old July 23, 2012, 06:13 PM
SpaceSquad's Avatar
Do you need the 1TB desperately? It would be a bit more expensive...but a 60ish GB SSD paired with, say, a 500GB HDD would let your OS boot way faster...install games/programs/locate My...Whatevers on the larger drive.
Worth looking at
-Space
Old July 23, 2012, 06:17 PM
BigPhatPaulie's Avatar
Not worth it for a 60gb really seeing as modern 1TB drives are plenty fast
FOR PONY..... that is alll
Old July 23, 2012, 06:52 PM
SpaceSquad's Avatar
Even a 40GB intel SSD beats out a Velociraptor 10k by quite a margin in tests...and a small SSD starts around 50 bucks...get one with good read/write and it is at least something to think about.
PCMark HDD
PCMark SSD
-Space
Old July 23, 2012, 07:33 PM
I always consider an SSD when recommending a build. I'm a HUGE proponent of SSDs and their advantages, and try to include them wherever possible. BUT, this guy only has $800 and wants to play modern games in all their glory and edit videos. This means we have to put money on a decent processor and video card more than anything else. I just can't see any money in the budget for an SSD at this time.
In the future though, it's pretty easy to add a 60GB (or even better, a 120GB) SSD as a later upgrade to give his PC a much needed boost in responsiveness.
Old July 29, 2012, 04:19 AM
I have to agree with great_big_abyss, for 800$ there is not a lot of place to turn for playing games at 1080p and video editing. The new Seagate Barracuda ST1000DM003 has 1TB of space, a single platter, 64MB of cache and Seagate says will do 210MB/s read and 165 MB/s write, that is defintely worth considering as startup drive. A SSD can be added later. Also, it would not be bad to consider a used GTX480, they can go as low as 160 even on local kijiji/craigslist, or if you can scoop a GTX295, even they go as low 100-120 on ebay. You could also consider getting all the parts used, they don't have to be new right away. Also, 2 x GTS450 position themselves in between 470GTX and 480GTX due to their high clocks, so that would be another solution.
Budget CAD build Jim Johnstone New Builds 6 February 11, 2011 09:30 AM
First Build: $6,000 Budget WillieMammoth New Builds 26 December 11, 2010 03:32 AM
New budget build Evylldemon New Builds 13 November 24, 2010 07:00 PM
Budget Build - i3/i5 Make Melodic New Builds 4 April 10, 2010 02:42 AM
Budget build. Epmphasis on budget. Miek New Builds 6 February 4, 2010 09:46 PM
