Old July 22, 2012, 11:30 AM
Default Are these good parts?
I am a first time building and would like to know if this sounds like a good gaming build:
Motherboard: MSI Z77A-G43
CPU: Intel Core i5-3570
GPU: MSI Twin Frozr II GTX 570
SSD: Mushkin Enhanced Chronos 60GB SATA III
RAM: Team Elite 8GB (2 x 4GB) DDR3 1600MHz
HDD: Seagate Barracuda Green 1.5TB 5900 RPM SATA III
PSU: PC Power and Cooling Silencer MK III 500W Modular 80PLUS Bronze
Case: Antec Gaming Series One Illusion Black ATX Mid Tower
Thanks, guys!
Old July 22, 2012, 01:14 PM
Keltron 3030's Avatar
I would recommend at least a 650W PSU for that build, just to be safe. Also, I'm not a fan of the case, but that is a personal choice of yours, as all case selections are
FFFFFFFUUUUUUUUUUUU-
Old July 22, 2012, 03:01 PM
I would change the RAM to Corsair, Kingston, or some other brand with better track record. Are you using the SSD as a boot drive? I'm not sure 60GB will be enough but I never had a SSD, just a personal concern. Finally, how much more would a 2TB be?
Old July 22, 2012, 03:41 PM
ram go gskills
board go asus
hd go WD 2tb
ssd get @ least 120gb
if i had a 3570 i'd be runnin ram @ 2400mhz+ instead of 2200mhz
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old July 22, 2012, 08:46 PM
Here is my opinion on your choices.
Motherboard: MSI Z77A-G43 - Should be fine (I prefer ASUS, but would have no problem buying MSI)
CPU: Intel Core i5-3570 - sounds good
GPU: MSI Twin Frozr II GTX 570 sounds good
SSD: Mushkin Enhanced Chronos 60GB SATA III - I would wait out on the SSD until you can afford a 128ish GB model
RAM: Team Elite 8GB (2 x 4GB) DDR3 1600MHz - I would go to a different brand, but it will likely be fine
HDD: Seagate Barracuda Green 1.5TB 5900 RPM SATA III - I would go for a seagate 7200.12 or WD black
PSU: PC Power and Cooling Silencer MK III 500W Modular 80PLUS Bronze - good choice, but for a gtx 570 I would go to a 650W model. Any XfX, Seasonic, Corsair, antec power supply would also be fine.
Case: Antec Gaming Series One Illusion Black ATX Mid Tower - It should be fine, but may be a bit small. I have never used one or seen one in person.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old July 23, 2012, 12:54 AM
Think the opinions above are pretty solid..
60Gb ssd will be enough for os and maybe 1 medium sized game and some normal programs.. 120 (or 128 depending on the manufacturer) would be better though.
The PSU is a lil low as said.. also, I may be wrong, but didn't coolermaster or someone buy out pc power and cooling? if they did might be worth going towards the seasonic based ones mentioned above (coolermaster don't make particularly good PSU's)
If you get the ssd, any "green" or more back-up orientated drive is fine.. If you skip it then as said above the faster drives (7200.12 or WD black) would be better.
2 questions though,
What is your budget and where are you buying from?
You may be able to get slightly more for your money depending on where you are and where you plan to buy from.
If in Canada, memory express has a price beat rather than match, so you really can get some bargains if you put in the leg-work to find all the lowest prices and then submit them to memory express
Old July 23, 2012, 06:23 AM
You should definitely take what the other members are saying into consideration, and go from there, but I think you're off to a great start!
Like Dzzope said, what is your budget? Are you trying for price-performance or just capped at $500-$600?
Also, what's your monitor and resolution? 570's still a great card, but I don't universally recommend it anymore like I did a year ago...
Old July 23, 2012, 06:53 AM
Alpine's Avatar
evanheminger: im currently running a system with a SSD 60GB. It getting full very quick. Windows and 1 or 2 games. You should go with a higher SSD like a 80GB or a 120GB depeding of your $$ for sure. Also, you should also go with a bigger PSU, like a 650 or 750w. This is make more room from video card upgrade in the future.
• ► › I7 3930K|Asus P9X79 WS|Evga GTX 690 Signature|Corsair Force 3 120GB|Corsair H1000|Corsair Dominator Platinium 16GB 2133Mhz|
Corsair AX1200|Corsair 600T SE|Corsair SP2500|Corsair Vengeance 2000
• ► › I7 2600K @ 4.9Ghz|P67A-UD4-B3|12G G.Skill 1600Mhz|Noctua NH-D14|OCZ Vertex 2 60GB|EVGA GTX 580 SSC|Corsair AX650|Lancool PC-K62|
Old July 23, 2012, 07:16 AM
great_big_abyss's Avatar
As mentioned above, I would increase the size of the SSD, at least to a 120GB. I speak from personal experience. 60Gb was enough for my OS and 2 large games. Any extra games had to be installed on my HardDrive. Since your supplemental harddrive is a low power 'Green' drive, you'll find it to be quite slow, requiring you to 'switch' games when ever you go through spurts of playing them. Which is a HUGE pain in the ass. Just save yourself the trouble and go for a 120GB (or larger) SSD right from the get go.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old July 23, 2012, 07:29 AM
stoanee's Avatar
Spend a few more $ and get a better case. This is higly regarded for the price:
Bitfenix Shinobi Window ATX Mid Tower Gamer Case, Black at Memory Express
heatware
Tags
new build
[FS] Few old computer parts - mobo, few ram sticks and few parts GreenPC Buy/Sell & Trade 9 April 5, 2012 05:48 PM
Good Computer Parts Store Near Orlando Florida? Bond007 Off Topic 6 March 17, 2011 03:42 AM
Should I buy parts or is the Ncix Vesta i5 3050 a good deal Dstate25 New Builds 16 August 24, 2010 07:56 AM
what is a good Media player for a good price or any suggestions Shadowmeph HTPC Systems & Software 4 December 19, 2009 10:27 PM
