Old July 11, 2012, 05:56 PM
Default Review My Build/Give Suggestions
I built a pc two years ago and its been a terrible experience. Mostly because of the freezing and lock-ups in games. So this time i would like some advice in the compatibility of the part so i won't run into any problems.
1. My Pc will be used for gaming (minecraft to Crysis 2, BF3, MW3) also video encoding and stuff like photoshop. I would like it to run smooth.
2. $900 is my price point or lower
3. USA, California
4. Not that much of a fan boy of companies just want compatible parts, good price and performance.
5. Have a 23 inch monitor
6. I have read tons and frankly im tired of reading success stories of others build when my last one sucked. and cost my money ~1500 and it freezes constantly
7. I'm familiar with overclocking but i would like it to boost performance.
8. I would like to start ordering the parts because i have 5 brothers and one pc that crashes.
9. 1920x1080 monitor but recently everything on high settings. I would like good looking graphics and it to be smooth.
10. Don't care about noise and 1tb hdd would be good
CPU:i5-3570K
CPU Cooler: Corsair H60
Motherboard: ASRock Z68 Extreme3 Gen3 LGA 1155
GPU:SAPPHIRE Radeon HD 6850 1GB
Memory (RAM): G.SKILL Ripjaws Series 8GB (2 x 4GB) DDR3 1600
HDD: 1TB Seagate Barracuda
Drive: Asus 24x
PSU: Corsair TX750 V2 750W
Case: Thermaltake V9 Black Edition
Any Suggestions would help.
Old July 11, 2012, 11:28 PM
If your doing video encoding and photoshop I would look at getting 16gb of Ram and Maybe an SSD if it fits in your budget
Old July 12, 2012, 01:07 AM
What is the spec's of your last computer... Just cos your having problems doesn't mean that you necessarily did anything wrong or need a total new build to give the performance your looking for.
Old July 12, 2012, 03:18 AM
Ravenor's Avatar
If you are looking to overclock, I would stick to Sandy Bridge. Less heat when overclocked. A 2500K would do all your needs fine and save you a bit of cash. I would also look at an Asus Z68 Matx Gene motherboard. They are smaller but the overclocking potential is much better.
Old July 12, 2012, 06:01 AM
Ravenor's Avatar
Case : Antec 300 $54.99
PSU: Corsair TX650 $89.99
CPU: Intel SandyBridge $209.99
Cooler: Corsair H60 $64.99
Mobo: Gigabyte Z68X-UD3H-B3 $144.99(124.99 with rebate)
GFX: Zotac Amp!Edition 560Ti $209.99 (179.99 with rebate)
Memory: G.Skill Value 16GB 2x8 $87.99
Harddrive: Seagate Barracuda 1TB $89.99
Burner: Asus 24x $18.99
Total: $971.91 - $50 for the rebates $921.91
All prices from Newegg.com......not .ca :)
You can Change the GFX card to your liking but this combo with perform very well just about any game you throw at it. I know it will do BF3 with all turned to Ultra no AA, 8x AF @1920x1080. i know it's a smidge over your budget, but it's worth it....especially to get a decent board for overclocking.
Old July 12, 2012, 11:57 AM
My old pc build:
CPU: AMD Phenon 955 not oc
Gpu: xfx 5770
Memory: corsair cmx4gx3m2a1600c7
Psu: coolermaster 750w I went through two b/c the fist poped/fried
Motherboard: Asus m4a89gtd pro/usb3
CPU cooler: Corsair h50
Also I made some changes With the parts.
CPU cooler: hyper 212
I don't think I will be overclocking
Psu: seasonic 620w
Motherboard: ASUS P8Z77-V LK
Old July 13, 2012, 03:01 AM
You will definitely notice a difference BUT your on the edge of where an upgrade is needed. (though a GPU upgrade and more ram would help quite a bit)
I would go for a slightly better board than the LX from Asus.. The Asrock wasn't a bad choice but alternatively the Asus maximus gene is better than the LX and it's Matx(smaller board)
At least bump to the P8Z77 V Pro in my opinion.
Hyper 212 will allow you to oc reasonably well.
620 watt PSU should be fine for pretty much any single card set-up unless you put everything at max load and oc (which rarely if ever happens)
For rendering.. grab a 2x8Gb kit.. will be worth it. (the new samsung stuff is apparently very good)
nout wrong with a 4x4 kit but it leaves you less space to put in more in the future if you decide that you want more.
Could possibly save some on the case too.
Old July 14, 2012, 12:47 PM
Default New PC
Just got all my stuff and ready to build my new PC:
CPU: Intel Core i7 3930K, 6 core/12 threads, 3.9ghz up to 64gb
Mobo: Asus Rampage IV Extreme/LGA2011/X79
Monitor: Asus VK27Q 1920X1080,HD
Case: Antec P280
PSU: Enermax Galaxy Evo 1250w
Memory: Corsair Vengeance, 4x4 gig, DDR3, 1600MHZ
Video Card: Asus GeForce GTX 560 ti 448
OS: Window 7 Professional 64
Sound Card: Asus Xonar Essence STX
Water Cooling: Corsair H80
Primary Drive: OCZ VERTEX 3 SATA III 3.5" SSD, 240gig,
Secondary Hard Drive: Seagate Barracuda 7200 rpm, 3tb, 3tb, 2tb, 1tb plus external 2tb WD
Optical Drive: Pionner DVD, Pionner Blu-Ray
So it should installed and working by Tuesday July 17, 2012 at around 15:00, if everything goes well and I don't find a way to screw up things! So wish me luck it is after all my first time, I have read a lot of your comments observe a lot of YOUTUBE how to, so I feel I am ready to jump in!
Thank you all for your precious information I will let you know how it went if I survive the installation.
La Bellaescrima
Last edited by Labellaescrima; July 14, 2012 at 01:04 PM. Reason: wrote wrong information
Old July 14, 2012, 07:54 PM
Prolab's Avatar
Jealous!
But good choice on the parts. PSU is overkill but if your SLI or Tri-SLI'ing is a good choice.
Gaming Rig:
-Swiffy 655 & 360 rad, 360 XSPC Rad, HK Supreme HF, EK D5 top rev.2, AMD BE 1100T OC to 4.07 ghz, 16 GB G.SKIL F3-12800CL9Q-16GBXL, Asus Crosshair V, (2) XFX 6950 w/ XPSC WB, Crucial M4 128GB & 120 GB Vertex 2 EXT, (4) 2 TB WD Green Drive, Corsair AX1200, Win 7 Pro 64-bit
Server Rig
-AMD Athlon II 245 stock, Asus Mobo, 2 GB DDR2 Kingston, WHS, 500 GB WD Black, (2) 2 TB WD Green, (2) 2 TB Seagate HD, (1) Samsung 2 TB F4, Fractal Design R3, Antec 650 watt PS
Old July 25, 2012, 06:13 PM
Finally installed all the parts, the PC is working fine! Now I know what it feels like to be in full throttle mode, I am a happy, happy, happy person! Don't think I missed anything, although now I will need help to pick some games don't know what I like and don't know what to get... I am first time gamer so any of you expert on the matter please stand up and speak to me. Thank you for your wise information...
La Bellaescrima
I give up! Build my PC for me and the best one Ill buy Remy_85 New Builds 28 June 16, 2011 03:21 AM
my new build (plz give me some suggestions and opinions) joatabe New Builds 12 January 6, 2011 01:59 PM
can we give a bad review of a computer store Shadowmeph Member Reviews 26 November 29, 2009 08:24 PM
Planning a new build? Need a x64 bit OS? I have a DVD copy of Win 7 to give away! Triggz New Builds 12 March 22, 2009 03:17 PM
Looking to Buy TV Tuner Card, please give Suggestions!! (urgent) howdid HTPC Systems & Software 14 September 23, 2008 08:44 AM
