<~----> NZXT Switch 810 "Black an White" 2011 Build Water Cooled. - Hardware Canucks
Old July 10, 2012, 05:46 PM
Default NZXT Switch 810 "Black an White" 2011 Build Water Cooled.
Alright so this is my first Major Build with Water Cooling and Even some case modding involved!
My plans were to make this a Sapphire themed build cause im using a lot of sapphire parts lol. BUT Decided to Make a very nice and clean Black an White build With some white Lights. Also some case mods
PARTS -
Case, NZXT Switch 810
Board, Sapphire X79n Pure Black (Pre Release)
CPU, i7-3820 (Currently Stock speeds, Last board was having issues so i had to RMA it.)
Ram, 16gb of Gskill 1600 Sniper series
GPU's, 2 Sapphire 6970's (One Ref, one Non ref)
PSU, AX1200 ( Will be sleeving the cables Black and white.)
Main HDD, Corsair Force 3 240gb SSD
Storage, 3tb WD Green, 1.5tb seagate cuda, 1tb seagate cuda.
2 Black Ice Rads, 1 3x120 and 1 2x120 (Both in Push Pull config)
Koolance CPU Block 370SI
Koolance Res setup (80mm Diameter 120mm Tall)
10 Feet of Black Tubing 1/2 3/4
1/2 Barbs (Getting compression Fittings eventually)
NOTE - This System is far from finished.. Pics Below is of whats been done so far.
More to come, Just got an email from Frozencpu.com My $300 Order of water cooling stuff will be here by the 11th!!!! :D:D:D:D
Another order from Performance-pcs.com will be here the 12th :)
Old July 10, 2012, 11:00 PM
A seriously great case to build in to, I like what I see so far. Just for comparison here's one of my build.
Good Luck.
Old July 10, 2012, 11:05 PM
supaflyx3's Avatar
Am i blind, or do i not see a pump or res there...
Old July 11, 2012, 01:27 AM
Thanks, i still have a lot of work to do, and plenty of ideas brewing for mods :)
I got HDD mounting kits and painted them black so i could fit my drives in the 5.25 bays, looks cleaner in my opinion.
You have a nice build as well, how do those 2 small rads work? Temps?
Old July 11, 2012, 01:41 AM
Could be one of those Pump,Res,Rad combo?
Old July 11, 2012, 09:17 AM
BigPhatPaulie's Avatar
Yea its one of swiftechs AIO's, the pump and res are on the top rad
FOR PONY..... that is alll
Old July 11, 2012, 11:23 PM
Default Woot update!
So just got my order from frozencpu.
pump
tubing
clamps
fittings etc...
Also possible loop config, please tell me what you think.
"Evo" Scratch Built Water cooled PC Mnpctech Off Topic 1 January 21, 2011 06:14 AM
NVIDIA's "Fermi" Architecture White Paper ( Hard OCP ) gingerbee Press Releases & Tech News 0 October 1, 2009 11:20 AM
is there a noticable gain to switch from 3/8" to 1/2" tubing? quikgp Water Cooling 8 May 12, 2009 04:26 PM
Water Cooled -NZXT Tempest jay51 Case Mods, Worklog & Gallery 48 October 3, 2008 11:26 AM
Internet security moving toward "white list" @ CBC.ca sswilson Reviews & Articles from the Web 1 September 17, 2007 09:04 PM
