-   -   final touch on build (http://www.hardwarecanucks.com/forum/new-builds/55319-final-touch-build.html)
karolis July 7, 2012 10:28 AM
i come here again to ask you guys if the all components are ok.
cpu Intel Core i7-3770K Ivy Bridge 3.5GHz
mobo ASUS SABERTOOTH Z77 LGA 1155
ram CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
cpu cooler CORSAIR H100 (CWCH100) Extreme Performance Liquid CPU Cooler
gpu EVGA gtx 680 2gb GDDR5 PCI Express 3.0
hdd Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA
ssd SAMSUNG 830 Series MZ-7PC128B/WW 2.5" 128GB SATA III
sound card Xonar Essence STX
case corsair 600t white edition
fan corsair sp 120mm
dvd room LITE-ON Black SATA DVD-ROM Drive Model iHDS118-04 - OEM
psu corsair ax850w profesional. or 750w
comment change some things if you see that are wrong:) tell if something missing thanks
Dzzope July 7, 2012 11:33 AM
Just so you know..
This is your 5th different thread on your new build (and many others on individual parts, that I can find quickly) you can just post in the original thread you made instead of making a new one every few days...
AND after being told a number of times that you don't need an i7 or 680 for gaming ( especially at 1080) your still set on them..
Please stop asking for advice unless you will listen.
pentiumvi July 12, 2012 08:10 PM
Well... if all you want to know is whether you're build will work together, the answer is yes.
But like the above poster has mentioned, you probably wont need some of those parts for what you're doing.
