Originally Posted by Dzzope Have you over-clocked the CPU?
Also really depends on the games you are playing..
Really if your changing cpu and motherboard then a z77 and i53570k is your best option for upgrade.. the AMD side is so far behind these last few generations they aren't even able to see the dust from Intel. |
Primarily playing Final Fantasy XIV, the game engine isn't well written and consumes lots of resources needlessly, alongside other newer titles such as Diablo 3, Skyrim, etc...
So you recommend going the Intel route? I avoided Intel CPUs originally because of their relatively high prices (compared to AMD anyways). Also, I'm finding that quite a few people claim a Phenom II X6 1100T will barely bottleneck a GTX 670, what are your thoughts?
Try giving the GPU a good clean.. the fan and heatsink could simply be covered in dust.. After cleaning my old 560ti I saw an 8 to 12c drop in temps (did clean the rest of the case out too)
71c is nothing to worry about anyway. |
Will try this, thanks for the tip! What temperatures should I start to worry about? For GPUs I've read that 80 C is bordering the safe temperature threshold.
The position of the fans are more important than their size..
Do you know the model of case you have.. have you got a fan on the side-panel facing the GPU? this will make a difference. |
My case. I will probably buy the larger case regardless, more fans, better airflow, and more room.
Those spikes are very strange and may indicate a problem, maybe virus or something else.. Worth a check, may help and doesn't cost.. If caused by the game then yes you are being at least occasionally bottlenecked by the cpu. Intel chip is only real benefit you'll see. |
I haven't delved into overclocking at all and I'd like to avoid it due to all the testing, experimenting, and knowledge needed to get it right and stable. As mentioned above, very likely it's the game's doing since everything else runs smoothly on my rig.
If Intel is the way to go would you mind helping me pick out a CPU and mobo? My Intel knowledge is outdated at this point.
