So, the title says it all.
I'm seeking advice and parts to build a computer that will allow me to max anything on the market right now and will be able to max anything that comes out for the years to come with just so minor adjustment/overclock
1- Mainly gaming computer
2-Buying from Canada
3- I'd say I like intel and Nvidia parts the most.
4- I plan on overclocking at some point but, I'm not really use to it so I would like the PC to max anything out of the box.
5- I'm only on the planning phase but I would buy it in the coming months
6- Planning on playing on 1900-1080 resolution for now, probably will go up to 2560-1440 at some point
As of now, I was thinking of going with those parts
2x Gigabyte 670 OC:
Gigabyte GeForce GTX 670 OC 980MHZ 2GB 6.0GHZ GDDR5 2xDVI HDMI DisplayPort PCI-E Video Card - DirectCanada, and I'm thinking of adding 2 more in the next 2 years. (I'm pretty sure they said an update would allow 4 way sli with the gtx 670)
Have no clue what CPU to get.
asus rampage IV extreme mobo:
ASUS Rampage IV Extreme E-ATX LGA2011 X79 DDR3 SATA3 USB3.0 5PCI-E16 SLI CrossFireX Motherboard - DirectCanada
16gb of ram, don't know which one to get though.
1000 watt PSU, in order to have some headroom for OC if I ever get there.
So tell me what parts you think I should add or change! Thx
