-   -   Advice & Suggestions on first build under $3k budget (http://www.hardwarecanucks.com/forum/new-builds/55036-advice-suggestions-first-build-under-3k-budget.html)
TBGAPowa June 25, 2012 02:01 PM
-I have this question posted on multiple forums so bare with me here as my replies will be much slower.
-AS FOR THE PEOPLE recommending me WC I honestly feel intimidated by it. I chose an air cooling case but I still am not sure to choose a water cooling enabled one since I am not positive if I go WC in the future.
-I will order from mostly canadian sites but will order from other places if necessary. The preferred retailer list I posted isn't that vital.
UNAVAILABLE ON NEWEGG CANADA:
Monitor: Dell UltraSharp U2312HM
CPU HSF: Thermalright Silver Arrow SB-E
Headphones: Sennheiser PC 350 or 360
Tablet: Wacom Bamboo Splash
This is my first build from scratch my gaming orientation leans on rpgs, mmos, action-adventure and rts for the most part and less so for fps and racing games.
Approximate Purchase Date:
By the end of July
Budget Range:
Under $3k subtotal including everything base system, monitor, peripherals etc…
System Usage from Most to Least Important:
Extensive gaming and production/rendering in autodesk and other 3D/CG art software
Parts Not Required:
Not planning on getting a custom water cooling system just yet
Preferred Website(s) for Parts:
Newegg Canada
TigerDirect Canada
Canada Computers
NCIX
Country:
Canada
Parts Preferences:
Nvidia, visuals for the most part
Storage Space:
2TB minimum
Overclocking:
Likely
SLI or Crossfire:
Possibly SLI
Monitor Resolution:
1920x1080 or 2560x1440. I would like to have games on maxed settings, AA would be nice and what ever gaming technology optimization available
Additional Comments:
my newegg wishlist
anything sold out on the list i will look for else where, as long as they have good enough return policy
Really looking for some of the top and latest support with longevity, durability and silence
the rig would be placed in the basement which is usually around 20C, during the humid summer it should be closer to 30C room temp but we almost always AC then. the only thing about the basement i am worried about is if airflow wouldn't be good enough for the rig
would a heatsink fan suffice for now? if i ever choose to SLI would water cooling be needed then?
dandelioneater June 25, 2012 02:35 PM
How about:
3930K, ASUS P9X79 Motherboard, 256GB Crucial M4, GTX 680, 4x4GB RAM, (or 4x8GB if you need more ram), AX 850 PSU. I'd go with something like that if you have a 3k budget.
TBGAPowa June 25, 2012 02:37 PM
Quoted from a member named lehpron from the EVGA forums "But, in order to maintain your CPU stabilty; your RAM, HDD, motherboard, PSU, etc all have to be in sync and stable too. So while the CPU could theoretically take the punishment, total system stability depends on the other junk in the system."
How Long Before Failure ?
i hope the hhds would suffice, they do get great ratings i believe the others are good enough.
is 16 gb RAM 1600 enough or should I go higher 1866/2133/2400?
what do you think think about this monitor?
Yamakasi Catleap 27" LED 2560x1440 WQHD S-IPS
ZZLEE June 25, 2012 03:10 PM
Newegg.ca - Microsoft Windows 7 Ultimate SP1 64-bit 1-Pack - Operating Systems
the only version worth buying.
the others wont support 16 GB of ram and defenitly wont support 32 GB of RAM .
TBGAPowa June 25, 2012 03:13 PM
wow thank you , that would have been a severe mistake purchasing home premium lol
[nK]Sharp June 25, 2012 03:24 PM
Should try and pick up some quality monitors while you are at it too. Unfortunately ncix and all the other Canadian retailers don't stock Korean ips monitors yet so you would have to go on ebay to get one, about $400 for one.
Should also try and get an ssd if you still have money after getting the main components. I avoid buying all my parts from newegg simply since ncix always has a sale every week which usually has better prices, I think I have bought only one thing from newegg since they opened their Canada site now.
wirerogue June 25, 2012 03:30 PM
http://sphotos.xx.fbcdn.net/hphotos-...67247534_n.jpg
just helping out...
Pabz0r545 June 25, 2012 04:29 PM
let me fix that for you :punk:
Originally Posted by dandelioneater (Post 637366)
How about:
3930K, ASUS P9X79 Motherboard, 256GB Crucial M4, GTX 690, 4x4GB RAM, (or 4x8GB if you need more ram), AX 850 PSU. I'd go with something like that if you have a 3k budget.
TBGAPowa June 25, 2012 05:46 PM
direct quote from member lehpron from the EVGA forums, sorry its huge but this sums up why i chose the type of mobo, GPU and CPU. but of course still subject to change
"Most modern games are threaded for between 2-4 cores, and it has been a slow progress adoption since quads have been around for six years, duals for eight years. meaning, a 6-core won't make a difference today. New games take 2-3 years to make from the ground up, so in that time, it will make a quad that much more important. Only get the 6-core for your professional work, not for gaming.
3770K is a 22nm quad and half the die area (thus half the actual power and thermals if set at the same frequency) as 32nm i7-3900's 6-cores; mathematically, they should overclock better, but Intel differed from tradition of soddering the CPU die to the IHS (integrated heat spreader) by using a thermal grease with Ivy Bridge which tends to artificially raise temperaturess. This prevents anyone from really being able to push it except for those using cryogenics; so in the end, all Sandy and Ivy processors reach a max of approx 5GHz regardless of number of cores.
So it all comes down to the board really; X79 can support up to 4-way SLI (in quad x8, or a pair of full x16) configs while Z77 is limited to just dual x8's. If you're serious about longitivity in terms of having the room for future graphics cards and not change the board (which definitely need more bandwidth than current), then X79 is the only option. For CPU, either get quad 3820 or 6-core 3930K depending on how often your professional uses need 12-threads or not.
BTW, as for the GTX670's, get the 4GB card. We'll soon see a new standard for mainstream monitors that used to be the reign of medicial professionals, their total single display res equals to a modern multi-display setup. So if you intend on at least one in the next two years and not upgrading graphics for it, then you should plan ahead with a 4GB model and get 3-way SLI by then to compensate.
TBGAPowa
Really looking for longevity and durability I chose a gtx 670 in hopes of being able to run graphic intensive art programs and gaming on high settings for at least two years before upgrade/new build.
This part will require an edit for realism.
In two years, a pair of GTX670 will have the performance equivalency of a future mainstream card (i.e. "GTS850" )and unable to run those games appearing then at high details without having the frame rates dip whatever is high-end at time. So either plan to get into 3-way or 4-way SLI (meaning you need to get a 4-way capable board in the first place, i.e. X79), think about upgrading your graphics card much earlier than two years, or settle for less visuals as times passes especially if you plan a higher resolution monitor someday. Most games are GPU-intensive, so if your resolution doubles the pixels, you cut your frame rates in half.
The only way you can truly have longivity is if your expectation is much lower than what is available for purchase. If you want max detail at smooth rates, then that is only possible today, it isn't possible next year with this year's configuration running next year's games. Just so you know, many folks on enthusiast websites like these upgrade often as a hobby, they choose to keep up with technology in order to maintain their preference level in every new game; I personally see it as a hassle. So you have to decide your upgrade tendencies beforehand and plan ahead, beyond this upcoming build. "
