Old June 19, 2012, 10:32 AM
Trial Member
Default Should I or Should I not?
Hi all,
I'm building a new gaming right and well I bought a motherboard already which is the ASRock Z77 Extreme 4. However I feel like switching to the ASUS Maximus V GENE. Do you think I should switch motherboard or is the one I have already better? I also plan on SLI 2 670s on this rig.
Let me know what you guys think, Thanks.
Old June 20, 2012, 02:12 AM
bigFOIG's Avatar
I wouldn't bother switching out, there's nothing wrong with the ASRock. I don't think there's anything the Asus can do that the ASRock can't, so I would just save my money. The black and gold on the ASRock looks sick by the way,
Old June 20, 2012, 07:00 AM
francisw19's Avatar
I'd stick with the ASRock board since you are planning to run SLI cards. Things will be a bit tight on the Asus board since it's mATX - those cards will be right on top of each other and will likely run a bit warmer than usual.
Old June 27, 2012, 05:50 PM
I ran the asus board its tight but bulletproof
