Old June 17, 2012, 01:31 PM
monocycliste's Avatar
Default Final Advice Needed on my Build (~1000$)
Hi,
I think this the final version of my build that I will purchase at the end of the month (hopefully the discounts will be as good at the end of the month!!).
That being said, I want advice just to make sure everything fits together and if you have suggestion for other, better parts, feel free to tell me. I will purchase from MemoryExpress as they offer price beat and PC Assembly. My budget is 1000$ including shipping and taxes, and I live in Canada. I already have a 1080p Dell 23" monitor and a 15" IBM monitor 768p).
I will be using this machine for video editing mostly.
Case: Corsair Carbide 300R 89.99$
Price Beat Request from Canada Computers 64.99$
Final Price: 58.74$
Power Supply: Antec EarthWatts EA 650W 64.99$
Motherboard: Gigabyte GA-Z77-D3H 134.99$
Pricebeat request from TigerDirect.ca 119.99$
Final Price: 116.24$
CPU: Intel Core-i7 3770 324.99$
Price Beat request from DirectCanada.com 316.03$
Final Price: 313.79$
RAM: 16GB of Patriot G2 Series (4x4gb) 99.99$
Price Beat Request from NewEgg.ca 84.99$
Final Price: 81.24$
GPU: Sapphire Radeon 6850 179.99$
Price Beat Request from DirectCanada.com 148.72$
Final Price: 140.90$
Hard Drive: Western Digital 500gb Caviar Blue 74.99$
Price Beat Request from NCIX.com 69.99$
Final Price: 68.74$
Keyboard & Mouse: Microsoft Wired 400 19.99$
Price Beat Request from DirectCanada.com 13.01$
Final Price: 11.27$
PC Assembly : Assemble Hardware at Memory Express 40$
Total (before price beat): 1 029.92$
Total (after price beat): 895.91$
As I said in the earlier, this is for video editing mainly and I don't plan on overclocking.
Old June 17, 2012, 07:42 PM
Old June 17, 2012, 08:28 PM
dustin1706's Avatar
Looks good. Do you already have an OS? Also, maybe you don't need one (or already have one), but an optical drive of some sort?
If it were me i might think about going with a WD black instead of blue for $15 more. Also, Since you are not overclocking or running tons of hardware you should be fine, but again if it were me, I would think about adding one or two more low speed fans to the case since it only includes two.
Rig1 in "My System Specs"
Rig2: Q6600, P5DN-D, GTX650, 4GB HyperX, LG BD drive, TT armor case, ek supreme HF, 655 pump, XP
Dell XPS17 - i7 2820QM, 8GB ram, 1920x1080, BluRay, GT555m 3GB, 240gb Neutron GTX, 640GB Seagate, Win7 64
Server - i5 3450, Asus P8Z77-I Deluxe, 4GB DDR3, LSI MegaRAID 9240-8I, OCZ Vertex 4 120GB, 2x SG Barracuda 3TB(RAID1), 2x WD green 2TB(RAID1), Fractal Design Array R2, WHS 2011
Old June 17, 2012, 09:10 PM
I have a few old optical drives at home which I will use to install the OS that I already have.
Depending on the prices of all the parts at the end of the month, I will consider more fans and small upgrades (actually buying a new optical drive, maybe 120gb SSD) depends on the prices.
Old June 17, 2012, 09:17 PM
great_big_abyss's Avatar
I know you're probably waiting for you SSD, but there's a sale in the BST with an Intel 520 Series 120GB for $130. That's a crazy good price for a top of the line SSD.
Just thought you should know.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old June 18, 2012, 12:00 PM
Thanks for the link, but HDD or SSD are not my priority as I can just re-use the one from my current computer (and maybe buy a SSD later), same goes for optical drive.
On another note, I might be able to push my budget a little bit more and I want to invest that money into a better motherboard, which of these should I take? (these a the price after price beat from memoryexpress)
Gigabyte GA-Z77X-UD3H - 143.74$
MSI Z77A-G45 - 134.99$
ASUS P8Z77-V LX - 128.43$
ASUS P8H77-V - 131.14$
Video editing build - Where to buy parts from monocycliste New Builds 10 June 8, 2012 04:51 PM
1k to 1.5K multimedia (video editing) build fjanicki New Builds 9 October 26, 2010 03:13 PM
$5,000 Video Editing Rig - First Build - Suggestions and Advice Gangifilms New Builds 7 June 20, 2010 09:23 PM
Video Editing PC Build Help Deemo New Builds 9 April 7, 2010 05:37 AM
Video editing build johndh New Builds 6 December 6, 2009 06:19 AM
