Old June 22, 2012, 06:37 AM
Originally Posted by JJThomp View Post
If you can get away with a 120gb SSD do it... it will be much faster than that Caviar Blue. However a storage drive is nice to pair with them and if you have any files you change a lot you shouldnt keep those on your SSD.
Thank you I will surely keep this in mind.
Old June 22, 2012, 07:40 AM
great_big_abyss's Avatar
Ahhh, never mind for the video card. It was a 7970 GHZ edition, not the GTX660. So, you're good to go with the 7850 if you like...
As to what JJThomp said, I'm in agreement. Replace the Caviar Blue with a 120Gb SSD for the moment, then save up and buy a storage drive a little later. As long as you don't download any media and store them on your SSD, you shouldn't run out of room just yet. But you WILL want to pick up a storage drive fairly soon.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old June 26, 2012, 06:31 AM
I was actually thinking of either getting a seagate momentus XT 500GB, if SSD is not an option (budget).
Thanks Guys.
First gaming pc, need advice. CarlosGrosso New Builds 8 March 21, 2011 01:10 PM
New gaming pc advice kanadien New Builds 12 December 14, 2010 12:57 AM
mid gaming for $600 need advice leland459 New Builds 7 July 15, 2010 08:40 AM
Gaming PC - Advice eXtreme New Builds 12 June 15, 2010 09:04 PM
Advice: gaming and more for <$1,600 CAN? Jimmbo New Builds 8 November 2, 2009 06:33 PM
