  #21 (permalink)
Old June 11, 2012, 02:49 PM
Yep, looks solid.
  #22 (permalink)
Old June 11, 2012, 03:24 PM
sorry bout I am wondering what the difference between OEM and standard windows 7 is?
  #23 (permalink)
Old June 12, 2012, 01:52 AM
Dzzope's Avatar
OEM is locked to the computer the standard is yours.. you can have it on any computer you own but only 1 at a time I think..
oem = locked to current build
standard retail = yours. can change the pc it is on.
  #24 (permalink)
Old June 12, 2012, 09:17 AM
thank you
  #25 (permalink)
Old June 12, 2012, 03:25 PM
Bond007's Avatar
Given what you want and your resolution I think the build looks pretty good.
New computer Gamer-Budget Build drgoodvibes New Builds 10 November 16, 2010 07:07 PM
First Build In a While, Mid-range Gamer. CanadianZX New Builds 2 April 15, 2010 08:43 AM
My potential first build, low budget gamer johnnyblazzwa New Builds 21 December 15, 2009 10:46 AM
Cheap Gamer Build 666$ Simon493 New Builds 17 August 7, 2009 03:17 PM
AMD Phenom II Build - $1500.00 gamer/multimedia smacc New Builds 15 April 3, 2009 05:35 PM
