Old June 10, 2012, 03:55 AM
Default better graphic card for my system
hello, want to buy a new graphic but difficult to choose ati 6000 or 7000 series. because im worry pcie 3.0 graphic will not working finely on mobo msi p67a-c45 thats pcie 2.0 only.
spec here,
intel i7 2700k
kingston 4x4gb 1333mhz
msi p67a-c45
psu silent pro 600watt
2tb hdd western digital green sata3 7200rpm
led samsung 23'
before this i used asus gtx260. need advice. ty
Old June 10, 2012, 05:29 AM
pci-e 3.0 will work no problem on that board. (at 2.0 speeds but you would need like 2x GTX 690 to see any difference)
Old June 10, 2012, 05:41 AM
What is your budget?
All pcie 3.0 graphics cards work perfectly fine in a pcie 2.0 motherboard.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old June 10, 2012, 06:41 AM
around $350-$450. i will get xfx7870 or 7950 soon. ty all. :)
Old June 10, 2012, 12:55 PM
With that budget I say GTX 670 and call it a day. If you have to go AMD(ATI) then I would go for the 7870.
Old June 10, 2012, 06:27 PM
Have to say the 670 is an awesome card.. No personal experience of the new AMD's but I changed from an AMD card last year as I was constantly getting glitches and problems with AA.
From reports of some people the drivers aren't getting any better either.
Your choice. a 670 is easy better than a 7950 and close to a 7970 and IMO the better driver support from Nvidia (along with cooler and lower power) make the 670 the better card.
Old June 10, 2012, 06:49 PM
Phill's Avatar
got my Gigabyte GTX 670 Windforce for $395 not long ago. I think it is a great card.
Old June 11, 2012, 03:54 PM
hossdaddy's Avatar
heres what I would look at;
EVGA 02G-P4-2670-KR GeForce GTX 670 2GB $419.99 + free shipping
XFX Double D FX-787A-CDFC Radeon HD 7870 GHz Edition 2GB $339.99 - $20 mir + $12 shipping + free game.
Main System:
i5 3570k @ 4.6ghz | GA-Z77X-UD3H | Gigabyte GTX 670 | 8gb Redline 1600mhz | CM 690 | Logitech G9x | Mushkin Cronos 120gb ssd | Benq 24" | CM Hyper 212+ | Seasonic 750w | X-Fi Titanium | Sennheiser 350 | Razer blackwidow | Win 7 64-bit
Backup System:
AMD X2 7750 BE @ 3.0G | Asus M3A78-CM | 2x2gig 800mhz 4-4-4-12 | SB LIVE | Samsung 22" | Asus 9800gt | Antec NEO 620w | Logitech G5 | ThermalTake Matrix | Arctic Cooling Freezer 64
Old June 19, 2012, 08:34 AM
ty all. but, could I run gtx 670/ati 7970 on the silent pro m600w PSU in my sig rig or would I need to upgrade to a better PSU?
Old June 19, 2012, 08:49 AM
SugarJ's Avatar
Check out SKYMTL's latest 670 review. The reference 670 with a OC'd 6-core CPU only pulls 325w from the wall at load. 7970 pulls 375w. Either way, your PSU should handle it no problem.
Gigabyte GTX 670 WindForce OC Review
i need an graphic card for x4 slot jksynapse Video Cards 6 February 18, 2012 03:27 PM
Will another graphic card fit? biagio1661 CPU's and Motherboards 3 January 15, 2012 01:21 PM
Looking to Upgrade my Graphic card siegfx Video Cards 10 December 4, 2011 02:34 PM
graphic card for PCI-X 64-bit/133 MHz slot jksynapse Video Cards 2 January 27, 2009 06:04 AM
