Old June 19, 2012, 08:55 AM
hossdaddy's Avatar
looks like you should be ok.
Main System:
i5 3570k @ 4.6ghz | GA-Z77X-UD3H | Gigabyte GTX 670 | 8gb Redline 1600mhz | CM 690 | Logitech G9x | Mushkin Cronos 120gb ssd | Benq 24" | CM Hyper 212+ | Seasonic 750w | X-Fi Titanium | Sennheiser 350 | Razer blackwidow | Win 7 64-bit
Backup System:
AMD X2 7750 BE @ 3.0G | Asus M3A78-CM | 2x2gig 800mhz 4-4-4-12 | SB LIVE | Samsung 22" | Asus 9800gt | Antec NEO 620w | Logitech G5 | ThermalTake Matrix | Arctic Cooling Freezer 64
Old June 19, 2012, 10:31 AM
thanks!
Old June 19, 2012, 12:45 PM
hossdaddy's Avatar
so which card are you getting, the 7950 or the gtx 670? Once you pick a card you need to pick a model.
Main System:
Backup System:
Old June 19, 2012, 10:22 PM
maybe gtx670, but dont know what brand to pick. hmm
Old June 20, 2012, 04:50 AM
hossdaddy's Avatar
give this a read,
Gigabyte GTX 670 WindForce OC Review I have it and love it!
Gigabyte GeForce GTX 670 OC 980MHZ 2GB $429.99
Main System:
Backup System:
Old June 20, 2012, 12:34 PM
sure ill grab it soon!
Old June 22, 2012, 09:26 PM
which card and brand did you go with?
Old June 23, 2012, 11:09 AM
asus maybe. its ok right?
  #19 (permalink)
Old June 23, 2012, 01:02 PM
hossdaddy's Avatar
yeah but over priced I think. I would seriously go with Gigabyte or eVga.
EVGA GeForce GTX 670 915MHZ 2048MB $412
Main System:
Backup System:
  #20 (permalink)
Old June 23, 2012, 07:48 PM
Dzzope's Avatar
Think the Asus is worth the premium over the EVGA but the Gigabyte is seriously good value.
i need an graphic card for x4 slot jksynapse Video Cards 6 February 18, 2012 04:27 PM
Will another graphic card fit? biagio1661 CPU's and Motherboards 3 January 15, 2012 02:21 PM
Looking to Upgrade my Graphic card siegfx Video Cards 10 December 4, 2011 03:34 PM
graphic card for PCI-X 64-bit/133 MHz slot jksynapse Video Cards 2 January 27, 2009 07:04 AM
