Old June 9, 2012, 06:45 AM
Default Watercooled - Finished Product!!! ***New Build*** (UPDATED WITH PICS)
Hey guys,
I just wrapped the build up about an hour ago. This is my first build and first attempt and watercooling.
I am ridiculously happy with the results. I didn't quite have the confidence before, but now I am happy I decided to go at it myself.
I have probably only had 10 hours of sleep in the past 5 days.
Almost seems time for double double from Timmy's!
By kyle87t at 2012-06-09
By null at 2012-06-09
Old June 9, 2012, 09:17 AM
mattlef's Avatar
First i would edit the post removing information about how you acquired your copy of windows.
Secondly, it sounds like the board isnt even posting. Do you have a speaker to connect to the board to see what post codes you're getting? does your board have an LED post board?
My Rig:
Motivate TJ07
Check out my Build log!!!
Motivation: Sponsored by Galaxy
Upcoming Changes/Upgrades:
Check the build-log for more
Old June 9, 2012, 03:09 PM
It seems it was already taken care of. :D
I got through the problem I had earlier. I just stabbed the F11 key a million times and got into BIOS.
I am running an MSI M77A-GD65.
Anyone have any advice using these BIOS?
Old June 9, 2012, 03:38 PM
mattlef's Avatar
the issue you had is that the os drive wasnt plugged into the same sata headder that it was in before. So basically in the bios you need to go to the boot selection and select the os drive as the primary drive to boot from.
This should fix everything
My Rig:
Motivate TJ07
Old June 9, 2012, 05:01 PM
Nice build (pretty much what I would ideally like) though I'm not too sure of the 3 fans on the top of the case. I suppose thats an issue of room though?
Old June 9, 2012, 05:13 PM
It is an issue of room. I cannot fit the radiator and 3 fans inside the case. Not a huge deal. I don't care too much what the case looks like. I modified the poop out of it. :D
I just check the CheckBIOSII and it shows my CPU running at about 34 degrees celcius idle. I'm running an I7 2600k. Is this normal?
Old June 9, 2012, 05:15 PM
I would have thought that it would be a bit cooler than that but the real test is at load.. Idle temps are meh...
Whats your load temps and what is the CPU running at (if it's over clocked, what clock and over voltage)
Old June 9, 2012, 07:24 PM
Sweet Joe, nice setup... you beat me to it.. able to take internal pics without lighting...
Also, I know you've done it before, mind posting the specs again :p
Old June 9, 2012, 07:30 PM
Darksword's Avatar
Old June 9, 2012, 10:09 PM
or update your profile.
Finally finished the build....you thoughts? ginman522 New Builds 6 April 9, 2012 07:08 PM
Finished NZXT Phantom Build xhrrcollector Cases 11 January 4, 2011 10:20 PM
New half-finished build fails to boot. ImmaPC Troubleshooting 24 August 27, 2009 01:50 PM
Finally finished my I7 Build quikgp New Builds 11 August 12, 2009 07:07 AM
Just finished my 1st build Dogger1 New Builds 21 February 12, 2009 09:38 AM
