Old June 3, 2012, 08:39 AM
Trial Member
Default NEED HELP FIRST TIME PC BUILD
Hi building my first Pc but not sure what wattage Power supply i need to get please help the parts I'm using are:
  1. Asus P8Z77-V DELUXE Motherboard
  2. Intel i7 3770K
  3. Corsair 16GB (4x4GB) DDR3 1600MHz
  4. Corsair H100
  5. WD caviar black 1TB 7200 RPM
  6. Samsung 128GB SSD 830 series
  7. Sony 24x DVD Rewriter
  8. ATI Radeon HD6850 Graphics card
  9. 3 120mm fans
Old June 3, 2012, 08:42 AM
Overclocking.ca's Avatar
You should be fine with a 650 watt or 750 watt power supply from one of the following manufacturers:
Corsair, Seasonic, XFX or Silverstone
Old June 3, 2012, 08:46 AM
wirerogue's Avatar
500 watts should be enough.
tryout the corsair power supply finder as well, here is the link Learn & Explore
Old June 3, 2012, 11:28 AM
Adzsask's Avatar
In the nicest way possible, if you are using that small of a video card, an i3 and 4GB of ram will be plenty. Also 500 watts is plenty for that system as is.
Tags
first build , help with new build , need help , power supply , power supply wattage
Time to build a new PC BasariStudios New Builds 2 March 31, 2012 10:22 AM
First Time Build, Need Some Help! porkpork New Builds 13 November 5, 2011 11:34 AM
First time PC build Big Iron New Builds 9 December 19, 2010 04:08 PM
First time build soambiatch New Builds 7 August 25, 2010 05:56 PM
First Time Build pRefy New Builds 40 March 22, 2009 12:52 PM
