-   -   Molex Fan Adapter Problems?! (http://www.hardwarecanucks.com/forum/new-builds/54353-molex-fan-adapter-problems.html)
AdamHuw May 18, 2012 05:14 AM
Okay, so I have ordered a 'BitFenix Molex to 3 x 3-Pin Fan Adapter' because I heard somewhere that it allows me to have more fans in my computer running at once?..
So now I have it I have no idea on how to use it, where to plug it in for example.
I can see the 3 bits for my fans to plug into, but which I think is the Molex part, the big block thing, I have no idea what its for and I can't find anywhere for it to plug into on my motherboard.. Does it even go on a motherboard?!
Please help?
Thanks!
-Adam
sswilson May 18, 2012 05:15 AM
It plugs into one of the cables from your power supply. Nothing at all to do with your motherboard.
Jebusman May 18, 2012 09:23 AM
This is the molex cable:
http://upload.wikimedia.org/wikipedi..._connector.jpg
You probably should've looked into it a bit before just buying something on a whim.
Sound Solutions June 6, 2012 05:15 AM
Did you find the molex connector on the PSU?
