Old May 7, 2012, 02:28 PM
DaWaltz's Avatar
Default Is a Corsair AX850 power supply enough for a future SLI or Crossfire upgrade?
Hey guys,
I have just finished a LGA2011 build.
I7 3820
Gigabyte X79 UD5
32gb Patriot Viper Division 4 RAM
2x XFX XXX HD5770's in Crossfire
1 Vertex 4 SSD
4 assorted mechanical storage hard drives
it is currently powered with a Corsair AX850w power supply.
My question is, I am looking to upgrade to a GTX670 SLI set up in the future....will this supply be sufficient or should I step it up when I upgrade the cards?
Cheers
Old May 7, 2012, 02:35 PM
dandelioneater's Avatar
The AX850 will be more than adequate for 670 SLI. No worries
Old May 7, 2012, 02:48 PM
DaWaltz's Avatar
could I push it to x2 680's?
also I forgot to mention....my i7 is overclocked as well.
Old May 7, 2012, 05:20 PM
NSdeadly1's Avatar
Should be no problem. Considering many are powering dual gtx 580's with trouble and the 680's are even more efficient. I'm running dual 6950's and it runs like a dream.
Old May 7, 2012, 06:11 PM
Your good to go IMO.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old May 7, 2012, 06:23 PM
ipaine's Avatar
I power two 580's with the AX850, so you should be fine.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old May 7, 2012, 06:24 PM
I own the ax850. It will crossfire 2x680's and your cpu overclocked to the maximum stable clocks.
Old May 8, 2012, 11:43 PM
i wouldnt put money on it but id say you could SLI 690s on that bad boy.
Old May 9, 2012, 02:02 AM
Depending on the rest of his set-up but it would be a bit tight for comfort with 2k worth of GPU
850 should be fine for 2 680's though and if the tech keeps going for the power savings that this generation has brought then it should be good for a while..
Old May 9, 2012, 09:20 AM
DaWaltz's Avatar
Thanks guys.....It looks like I'll be good. Sweet, I was hoping to avoid buying a new PS it'd add a bit to my upgrade costs
Main Rig
Core i7 3820 @ 4.75 \ Gigabyte X79-UD5 \ Corsair H100 Cooler \ 32GB 1600MHz Patriot Ram \ x2 XFX XXX HD 5770 in Crossfire \ 128GB Vertex 4 SSD \ Corsair AX850w Power \ Corsair Obsidian 800D
Tags
32gb , 3820 , core i7 , hd 5770
Corsair AX850 - black and metal fragments in power supply Tempstar Power Supplies 11 May 26, 2011 11:39 PM
Time to upgrade the power supply? FlyingFish Power Supplies 3 November 23, 2010 03:18 PM
[WTB] Corsair (or similar) power supply Cowboy Buy/Sell & Trade 9 May 23, 2009 10:54 AM
What kind of power supply do i need to run 4870 crossfire! supernode Power Supplies 10 March 15, 2009 10:22 PM
[WTB] corsair power supply CTA Buy/Sell & Trade 0 December 9, 2008 01:24 AM
