Crossfire is a bugger.. and AMD is very slow at releasing profiles for new games (which means x-fire doesn't work with them until they do)
If your going to be using 2 cards for sure I would lean to a 560 Ti.. and a 850 watt PSU, a 750 will probably just drive them, but if you want to OC as well.. Gonna be a bit tight..
(sli 560 TI's will suck 430 watts at load, leaving just 320 for the rest of your machine on a 750 Watt PSU.. Assuming it can deliver the full 750..)
If you need to cut cost somewhere.. then a P67 board will allow you to OC and save a few bucks.. Very few features lost, (ssd caching, igp switching)
