Originally Posted by Dzzope "The backplate features a pair of dual link DVI connectors as well as full size outputs for HDMI 1.4a and DisplayPort 1.2."
As long as your monitor supports HDMI or Display-port (or get a converter, which I believe is possible) you have all 4 connections on 1 card.
On the 3d rendering:
What do you currently use?
How long does it generally take?
How often do you need to do it?
Just trying to see if the cost - benefit is like with the hex-core to the i7 2600k. |
Wow, That's Great! 4 Monitors, 1 Card...Waahoo!!! LOL! Still think I'm going to get dual 680's, I definitely want to try this SLI stuff! But even if I get 2 680's and ditch the 3rd and the radeon, I still save over $1,000!
Rendering...
I currently use:
Core 2Duo 6600 @ 2.4 GHz
8 Gig RAM (Although according to Win 7 it only have 3.97 Available ???)
XFX Radeon HD 4890 (!GB, 850 MHZ, 3.9GHz)
Most rendering takes overnight (hangs head in shame)
I only render a couple of times per month. However I run Adobe's Master Suite (5.5) All day every day, in and out of programs constantly. Hence the 4 screens.
p.s. thank for taking the time to help me out with this!
Jeff.
