Old April 26, 2012, 06:23 AM
trancewhiiz's Avatar
Interesting you're going with Vista as OS. May I ask why Vista over Win 7?
Old April 26, 2012, 08:35 AM
Dzzope's Avatar
Probably cos he already owns it?
if not good point.. get win 7... basically the same as Vista but more stable and better drivers.
Old April 26, 2012, 08:40 AM
BigPhatPaulie's Avatar
Not only that but vista is less bloated. Also if your sure you want a 6 core get the 3930k isntead. It only looses some clock speed and a bit of cache but its also $400 (maybe more) cheaper than the X.
At any rate good luck!
Old April 26, 2012, 08:51 AM
Nope, that was supposed to read Windows 7 Ultimate. Sorry about that. I am currently running Windows 7 Ultimate.
Old April 26, 2012, 08:53 AM
Originally Posted by Dzzope View Post
Intel 520's are simply the best sandforce based drive available and have a rock solid warrenty.
On the point of having 2 boxes... if your not in a huge rush for the renders.. why not just keep the q6600 doing the renders and save yet more on new builds...
If your going down the 2 box route that is.
This is probably what i am going to do for the first little while. And I will have a peek at the 520's
Jeff.
Old April 26, 2012, 11:06 AM
SpaceSquad's Avatar
Read earlier that Win7 is only detecting 4GB...do you have a 32-bit version of Win7?? Because that isn't going to be sufficient as it won't address your ridiculous amount of memory.
-Space
Old April 26, 2012, 11:19 AM
I am currently running Windows 7 Ultimate 64bit. Which is why I have absolutely NO CLUE why it is only detecting only 4GB of ram.
While so many people are reading this, I have yet another question. Apparently, the i7 3960X does NOT come with a fan. Should I choose to be an idiot and gt it anyway...how do I find a fan or an "air cooling heat sink"? that will attach to this board.
I do not want liquid cooling simply because I have no idea to to use it, hook it up, change fluid and most likely would end up electrocuting myself and starting a house fire.
So My plan is to purchase either the i& 3930 or the 3960X. What else do I need to attach to it to keep it cool?
Jeff.
Old April 26, 2012, 12:16 PM
great_big_abyss's Avatar
Most coolers will fit X79. You might want to consider one of the 'all-in-one liquid coolers like the Corsair H80.
  #19 (permalink)
Old April 27, 2012, 10:02 AM
Ncix has video in tech tips of installing an LGA2011 Series chip then the Corsair H100 on top of it, so, I figure, if I watch the video while doing it, I can do it too! LOL!
Jeff.
best gaming/multimedia mechanical keyboard? simsin Peripherals 7 November 10, 2011 06:55 AM
ASUS Adds Rumble Impact to Gaming and Multimedia with CineVibe Headphones FiXT Press Releases & Tech News 0 August 10, 2010 11:59 AM
[FS] i7 920 Gaming Machine LC0g Buy/Sell & Trade 26 February 19, 2010 02:32 PM
No budget multimedia/gaming rig build. Viceroy New Builds 35 October 21, 2009 12:14 AM
gaming/multimedia keyboard mo' power Peripherals 0 April 9, 2007 06:12 PM
