Old March 18, 2012, 07:48 PM
Talking New gaming rig , In need of help
Hello,
For my new computer I wanted to go with a Mini-itx size , here are the part im pretty sure to get :
( exept of course if you know better bang for the buck )
intel i5-2500k
Corsair H60
Evga gtx560 ti 448 classified
Psu not chosen yet but probably a corsair or silverstone, around 650w
the part Im stuck is the motherboard, ram and case.
the motherboard I have zero idea what is good.
The ram there is so much brand or product, I must admit im lost.
And finally the case I saw the Lian li pc-q08 but comment on newegg were saying that she were really noisy and I saw the shuttle SZ68R5 but the cooling seem low, and the power supply is only 500w, the evga website suggest minimum 550w for gtx560 ti
Just a final question, do you think using a mini-itx motherboard will really affect the performance overall ?
thanks again ^^
Old March 18, 2012, 08:13 PM
mini itx has throtling issues
you better off goin with something like a gene-z
unless you gonna run stock
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old March 18, 2012, 08:23 PM
thotling ?
well I dont think Ill be able to overclock in a mini-itx case.
but the thing Is that I dont think its possible to have a small case in higher than mini-itx :S and the price of mobo/case will go up for sure :S
Old March 18, 2012, 08:32 PM
my friends h60 pump failed and many reviews online say pump failed a well, I'd change the cooler to an antec 620 for better flow and flexible rubber tubing
Old March 18, 2012, 08:34 PM
Adzsask's Avatar
Just built a M-ATX rig for my friend, 2600K @5.2, 16GB 1866MHz RAM, 120GB SSD,2X 2TB storage, lian li MATX case, weighs under 25 pounds, and can be picked up with 2 fingers on each hand. He also tossed in a GTX 590 classy and that thing is a screamer, the case could literally fit in my full sized tower.
KaptCrunch's Avatar
all said and done.....if want small foot print size gaming box
whats wrong with game console is cheaper by the time rig is made
Old March 18, 2012, 08:36 PM
I didnt knew mini-atx existed :) gonna look for it , any idea on moderboard ? its my biggest problem atm
Old March 18, 2012, 09:03 PM
my freind bought one lol
Newegg.ca - ASRock Z68M-ITX/HT LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard
he's not happy cause of throtling when overclocked
but good for stock
you better off getting m-atx
one for sale AsRock z68 Mini-ITX 1155 Motherboard
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old March 18, 2012, 09:15 PM
a M-atx wont have OC problem ? any suggestion for board ?
edit: any thought on ASUS P8H61-M (REV 3.0 ) ?
Old March 18, 2012, 09:38 PM
Adzsask's Avatar
Gene Z are the best overclocking MATX boards from ASUS, I run an EVGA and it is a solid overclocker.
Gaming Sunglasses, your thoughts for Work and Gaming Arinoth Peripherals 20 February 13, 2012 11:24 AM
[WTT] *TRADED* My WaterCooled Gaming Rig ( LOT OF FREEBIES ) For your Gaming Laptop bautisj Buy/Sell & Trade 10 October 31, 2010 04:40 PM
