Old March 18, 2012, 10:51 PM
ASUS - Motherboards- ASUS Maximus IV GENE-Z/GEN3 ??
they are quit expensive, im actually trying to stay around the 1000$ ( canadian )
But if you think its necessary, maybe its possible to cut on some part
i5 2500k = 239.99$
evga 560 ti 448 class = 299.99$
asus...gene-z/gen3 = 189.99$
corsair tx750 v2 = 109.99$ ( or maybe you know a cheaper and better than this one )
corsair xms 4gbx2 = 55.23$ ( same as psu ) - full code : CMX8GX3M2A1333C9
Lian Li PC-V354B = 131.98$
h60 or h80(not sure it would fit) since I didnt find other one water cool kit : 70-80$
1097$ quit tight, I hoped for around 950 but yeah....any thought ?
Old March 18, 2012, 11:25 PM
I was looking around and I was wondering if it would be possible to fight like a noctua one. wich a pretty big overall but really good.
Old March 19, 2012, 08:16 AM
dandelioneater's Avatar
The m-itx boards have very basic bios' for overclocking. The zotac x68 AE was ok for me a while back, but at ~150 bucks you are better off going for the asus gene.
Old March 19, 2012, 09:12 AM
ern88's Avatar
I have a ASUS Maximus IV Gene board. And I am quite happy with it. It overclocks the CPU with ease and love the UEFI Bios. Great M-ATX board.
Old March 19, 2012, 10:01 AM
thanks :) now I have to find a way to cool the Cpu. the lianli v354 wont be possible to use cause of the psu that is quit near the cpu , only a water cooling would be able to fit ,
but ive heard some pretty bad thing about h60-h80 ( pump does ton of noise mainly , and other thing )
Old March 19, 2012, 10:41 AM
Adzsask's Avatar
The MATX build I did I used a noctua nh c14, It is a layed down version, still huge but fit really well in his case (lian li pc-v600f)
Old March 19, 2012, 11:26 AM
thanks, gonna check that, im still wondering if I will go with water cooling, gonna search for a silent one if possible , or ill turn for good to air cooling
Old March 19, 2012, 01:56 PM
Are you more worried about price or size? Although it looks like they have convinced you to go matx over itx.
AnandTech - SilverStone FT03: Nothing Else Like It
AnandTech - SilverStone Precision PS07: Temjin For Less?
Here are two great cases at two very different price points. Just wanted to give you a few more options, and these both work well with air cooling.
Edit: and the corsair H100 actually increased my idle noise level as the pump is louder than any of my fans!
  #19 (permalink)
Old March 19, 2012, 02:02 PM
sorry but those 2 case are really horrible in my opinion .
yah I saw lot of people saying the pump are making lot of noise, its why im maybe looking for other water cooling or are compact air solution that will fit
Gaming Sunglasses, your thoughts for Work and Gaming Arinoth Peripherals 20 February 13, 2012 11:24 AM
[WTT] *TRADED* My WaterCooled Gaming Rig ( LOT OF FREEBIES ) For your Gaming Laptop bautisj Buy/Sell & Trade 10 October 31, 2010 04:40 PM
