HOKAY! I wanted to buy all new parts & have Ncix assemble, but well.. XD The system I was considering wouldve probably been about $1200 (not incl tax & assembly.. not incl OS)
ANYWAY! For $590, is this worth it? CPU: Intel Core i5-2500K Processor, 3.30GHz w/ 6MB Cache (Jan 2012)
MB: Gigabyte GA-Z68X-UD3H-B3 w/ Dual DDR3 2133, 7.1 Audio, Gigabit Lan, 1394, CrossFireX / SLI (Jan 2012)
RAM: Vengeance 8GB DDR3 1600MHz CL9 Dual Channel Kit (2 x 4GB), Cerulean Blue (Jan 2012)
Case: Antec Three Hundred Case (Jan 2012) (very silent case)
2 x Scythe Slip Stream Kaze Jyuni 120MM Fan 800RPM 40.1CFM 10.7DBA (super silent fans)
extra 120mm cooling fans at the front.
Scythe Slip Stream Kaze Jyuni 120MM Fan 800RPM 40.1CFM 10.7DBA - Scythe - SY1225SL12L Power supply: Antec 650W Power supply
(from previous system, in perfect condition)
And, for $750, he would include the Patriot 120gb Sata III SSD as well.
(I have major thoughts AGAINST buying used SSDs/HDs from others, b/c I don't know if there's any malicious software on these items! Is there a way to wipe both so that they're seriously, completely, brandnew?)
I would like to get your advice ASAP!!!
OH! the seller also said that he could also
install 64bit Windows 7 Professional SP1 (not the usual Home Edition that comes with most PCs and laptops).
How do I make sure it's a legit copy of Win 7? And make sure he can't call MS afterwards, and ask to have the serial changed!?!?!
