Old March 6, 2012, 11:43 PM
Default Building new rig, need advice
1. Tons of gaming, occasional movie streaming and listening to music. I really just want to be able to run The Witcher 2 well and stream things for friends.
2. $1000-$1100
3. United States
4. I've got a soft spot for nVidia and Intel
5. I have a 750GB hard drive I might hook up but I'm not real attached to it and it's slow by today's standards
6. Yes but not many
7. Default speeds, overclocking scares me in ways nothing should
8. Three weeks from now? Before May in any case
9. I don't have a current monitor outside this laptop (1366 x 768) and I have no idea what monitor I'd like (but man would I love suggestions) and I don't want to factor in the price for one into this build.
This is a build from techreport.com with a different case, basically
Case: Fractal Design Define R3 Silver - $99.99
Mobo: ASUS P8Z68-V LE LGA - $137.99
GPU: EVGA SuperClockedGeForce GTX 560 Ti - $249.99
PSU: SeaSonic M12II 520 Bronze 520W -$79.99
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz - $224.99
RAM: Crucial Ballistix sport 8GB (2 x 4GB) 240-Pin DDR3 SDRAM -$42.99
HD: HITACHI Deskstar 750GB 7200 RPM - $99.99
Disk Drive: ASUS 24X DVD Burner - $20.99
Old March 7, 2012, 01:06 AM
bigFOIG's Avatar
This is a pretty popular monitor at a good price. 24" 1080p
ASUS VE247H 23.6IN Widescreen LED LCD Monitor 1920X1080 2MS 10M1DC HDMI DVI-D VGA Speakers - ASUS - VE247H
Old March 7, 2012, 01:36 AM
Silent_Avenger's Avatar
Originally Posted by bigFOIG View Post
+1 for that monitor I just got one and so far I find it great. Although it was pretty blinding at first because it was so darn bright. But yea I like it just don't expect much from the built in speakers they aren't the most powerful out there. I'll be picking another one of those monitors up on thurs to replace my philips so I have a matching set. Also you can get them a little cheaper here: Canada Computers | LCD/LED Monitors | Asus VE247H, 23.6" Widescreen LED Monitor, 1920x1080, 2ms(GtG), 10,000,000:1 (ASCR), 300cd/m. Or at least try and get it price matched to that price.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old March 7, 2012, 12:13 PM
I recommend a twin frozr or hawk instead of the superclocked, works out to be cheaper after rebate, and the hawk has a higher stock OC but both cards are awesome for OCing
Twin Frozr
Hawk
Old March 7, 2012, 02:17 PM
Bond007's Avatar
choices look pretty solid.
Old March 7, 2012, 02:51 PM
hossdaddy's Avatar
I do not like the cost of the gtx 560 ti's right now, especially considering that nvidia is dropping the gtx 6XX series in April. Id try to hold off on the gpu until the new cards come out. Unless you can get that card for under $200 then roll with it. Failing that the radeon 6870 @ $150-160 is the best bang for the buck right now.
Main System:
i5 3570k @ 4.6ghz | GA-Z77X-UD3H | Gigabyte GTX 670 | 8gb Redline 1600mhz | CM 690 | Logitech G9x | Mushkin Cronos 120gb ssd | Benq 24" | CM Hyper 212+ | Seasonic 750w | X-Fi Titanium | Sennheiser 350 | Razer blackwidow | Win 7 64-bit
Backup System:
AMD X2 7750 BE @ 3.0G | Asus M3A78-CM | 2x2gig 800mhz 4-4-4-12 | SB LIVE | Samsung 22" | Asus 9800gt | Antec NEO 620w | Logitech G5 | ThermalTake Matrix | Arctic Cooling Freezer 64
Old March 8, 2012, 12:06 AM
Cool, cool, cool.
I'm definitely going to get that Asus monitor you guys recommended.
And yeah alright I'll stick it out to see the 6xx series unless I see a super great deal on a 560
Thanks guys, you helped a ton!
Old March 8, 2012, 09:53 AM
Dzzope's Avatar
You have a 750 GB hdd but spec'd a newer one?
Get yourself an ssd instead of a second hdd.. Unless you think the current one is on it's last legs.
Personally, I'd look at the 7850 from ATI if you can't wait for the new Nvidia's (have a 560 TI and am reasonably happy, would be happier with a slightly larger card though as I like to bump up the msaa)
Also even at 1080, the 1 gb ram on a 560 TI (currently sufficient) is quickly becoming slightly low if you want it to last a few years.
Building An i7-870 Rig... nashx New Builds 8 January 9, 2011 10:10 PM
Looking into building new system, could use some advice. NobleArc New Builds 11 September 21, 2010 12:03 AM
Building a new computer - advice needed. appplejack New Builds 28 December 10, 2008 07:14 PM
Building my first PC. Rolay New Builds 12 October 12, 2008 07:06 AM
Building another rig! Kassela Troubleshooting 5 March 17, 2008 10:14 AM
