<~----> Need a Wireless Connection to my Custom PC - Hardware Canucks
Old March 5, 2012, 01:35 PM
Default Need a Wireless Connection to my Custom PC
I have recently put together a new custome built computer for video editing. As I was used to all the laptops I have around the house coming standard with a wireless connection, I overlooked this factor in my build. So now I do not have internet access on my new computer.
Can anybody give my some guidance/options on setting up wireless on this pc? Which wireless cards that will be compatible? Any installation tips? (I imagine the install is simple)
Below is the PC:
  • Intel Core i7 3930K 6 Core 12MB 3.2 GHZ
  • ASUS Sabertooth X79 ATX LGA 2011
  • Noctua NH-D14 SE2011 LGA 2011 Heatpipe Cooler
  • Corsair Vengence Low Profile 16GB 4X4 DDR3-1600 9-9-9-24 Dual Channel
  • Seagate Barracuda 1TB 7200RPM 64MB SATA 6Gbps HDD (OS/Programs)
  • Seagate Barracuda 2TB 7200RPM Sata 64MB Cache HDD (media)
  • Seagate Barracuda 2TB 7200 RPM Sata 64MB Cache HDD (pagefile/scratch/renders)
  • Corsair Pro Series Gold 850W PWR SPLY
  • Microsoft Windows 7 Pro
  • Gigabyte GeForce GTX 570
Thanks
Old March 5, 2012, 01:43 PM
stoanee's Avatar
How far from router to rig?
heatware
Old March 5, 2012, 02:15 PM
great_big_abyss's Avatar
Depending on your router, something like THIS?
That's assuming you want to go wireless with it. Best solution IMO is to put the router/modem next to your desktop so you can hardwire it.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; ASUS GTX650Ti Boost; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; Sapphire HD5870; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old March 5, 2012, 02:40 PM
The wireless router is not far from the computer. Just down the hall, basically seperated by a bedroom. Everything is in my apartment which is under 100 sq ft.
I already have wireless supporting all my other laptops when I fire them up. I would like to be able to hop on the internet with my new machine as well.
Old March 5, 2012, 02:45 PM
Okay, see first sentence of my previous post. As long as you have a relatively recent router, it should be an 'N'. Better yet, could you tell us what router you have? make and model #.
Old March 5, 2012, 02:52 PM
dandelioneater's Avatar
If you are unable to relocate teh wireless router to you main rig so that you can hardwire off it, you could just get a wifi pci card or a lynksys usb wifi adapter. It will work, but in the end wifi is never the greatest. What about powerline for your rig instead of wifi? It would be much faster and reliable.
Old March 5, 2012, 08:06 PM
Silent_Avenger's Avatar
Best thing you can do is to run a hard wire to it but you next best bet is to go powerline and then if that doesn't suit you go with a pci wifi card. Or if you're super cheap like me get a $2 cat5 cable from the dollar store and use a shared connection on a laptop you have
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Anybody using a Canopy based wireless broadband connection? Dr_BenD_over Networking 5 January 15, 2012 09:16 AM
home wireless dropping connection On2wheels Networking 2 November 23, 2011 06:30 AM
is there any benifet upgrading router from wireless g to wireless N? Shadowmeph Networking 4 April 26, 2011 07:12 AM
Wireless N Router & Wireless B/G Adapters cul8erppl Networking 11 September 3, 2010 01:02 AM
Wireless connection problem. Brinnie Networking 3 March 21, 2008 04:00 AM
