Originally Posted by MARSTG for case you can look at the Corsair Carbide 500R, would match perfectly with your H80 cooler, as for fans I am using Antec 120mm fans, with selectable speeds, you also have choice to select different colours for the fans, red green, blue, just remember that the green ones are really bright will iluminate a lot in the room if they are placed on the side of the case. Not a good idea if you sleep in the same room with the system, in this case you might want simple fans, no LEDs for the side |
ugg antec fans, okay for the money but theirs much better out there. Namely scythe, triebwerk and noctua as examples. Also heard cougar fans from europe are pretty sweet, albeit hard to get and bright orange
Its up to you really, ivy bridge itself seems worth the wait. As for the chipset, it might give vendors an opportunity to implement new proprietary designs into their boards that they've developed since SB. Mostly marketing gimmicks of course but sometimes worth it IMO.
