Old March 5, 2012, 04:30 AM
Default Thoughts on my Build
I'm planning on making a PC and i'm wondering if this is good and if you think i should change anything.
NZXT Phantom 410 Mid Tower Case Black
Intel Core i5 2500K
EVGA GeForce GTX 580 Superclocked/ASUS Radeon HD7950 DirectCu II 3GB (not sure which one)
ASUS P9X79 Deluxe Motherboard
G.Skill Ares F3-2133C9Q-16GAB 16GB (4x4GB) DDR3
Corsair AX1200 Gold Power Supply
Intel 320 Series 160GB SSD
Seagate Barracuda 1TB
Corsair Hydro Series H80 CPU Cooler (Unsure if i will Buy this or a Fan)
Any Help will be appreciated.
Old March 5, 2012, 08:04 AM
AmuseMe's Avatar
Why is this posted in the water cooling section?
Old March 5, 2012, 08:29 AM
stoanee's Avatar
You have an incompatible cpu & motherboard picked out. 2500K is LGA1155 and the ASUS P9X79 is LGA2011. 1200 watt psu is overkill unless you are doing additions later on.
heatware
Old March 5, 2012, 10:22 AM
AmuseMe's Avatar
Good catch man - completely missed me
Tags
build pc
New build would like your thoughts Wh0mpu5 New Builds 8 October 18, 2010 11:02 AM
Thoughts on a second build Bohrman New Builds 8 October 7, 2010 12:04 PM
Thoughts on this build? Ghlin New Builds 9 December 11, 2009 06:54 AM
Thoughts on my I7 build thunderstruck67 New Builds 24 August 14, 2009 10:38 AM
New here and a new build any thoughts bobiseverywhere New Builds 20 January 29, 2009 02:03 PM
