I just built two of these. Both worked right out of the boxes. No memory issues or motherboard issues. The Sugo 06B is very similar to the 5. You will need a slimline DVD drive - I chose a slot drive vs a tray which is a little more expensive. You will also need the slimline cable to power the drive (see Newegg product number below).
Not many choices on ITX 1155 motherboards, was looking for Gigabyte but couldn't find. Happy with ASRock but BIOS is not as flexible as the Gigabyte boards I have used in the past. That said, I didn't have to make
ANY BIOS changes - it set ACHI for the drive and automatically set the voltage and specs for the RAM (This Gskill 1600 RAM also worked with no issues F3-12800CL9D-8GBXL). The driver disk that comes with the motherboard will automatically install all the drivers after you install windows. It installs some bloatware so my suggestion is use the custom button and only install the drivers and avoid meta expresso or whatever the stupid software was called (I uninstalled it after I did it). This motherboard does not have wireless built into it but you can get a USB Wireless thing so I don't see that as an issue. It comes with 1 x MCE Remote Controller, 1 x Multi-Angle CIR Remote Receiver but I didn't use it so I can't comment on it. I assume it is for making your box into a TV controller as the remote has a number pad and 4 way button.
Boots up in 22 seconds. I only needed this as a workstation and chose a 90GB SSD. If you can use one 2.5" drive, you can throw away the 3.5" drive cage that dangles under the DVD tray, and create more space inside the case. If you need to use the drive cage you will have a hard time with the power supply wires butting up against the drive cage - good luck with that one.
I used the stock CPU cooler and the hottest I have seen is 40 C but it usually stays around 33 C.
Here's some pictures. I cleaned up the cables some after these pics were taken but there is still a lot of wires in a small space so I appolgize for the sloppiness of it. It gives you some idea of how little space you have to work with. I should have taken some pictures of it completed but I didn't. Sorry.
Probably need an HDMI cable unless you got one already. I also did not need a video card so you will have even less space to work it and it may run hotter due to lower airflow. You'll just have to see.
I played around with some tape and spray paint on the case just because I could. Obviously I am not Picasso.
I had fun and that was what is important to me. Good luck on your build.
O.S. Windows 7 Pro 64 $120.00
Processor Intel Core i5-2400 3.1GHz LGA 1155 95W $190.00
Motherboard ASRock Z68M-ITX/HT LGA 1155 Intel Mini ITX $120.00
RAM G.SKILL Ripjaws X Series 8GB (2 x 4GB) F3-10666CL9D-8GBXL $40.00
Case 11x9x7 Silverstone Sugo SG06B w 300 PSU $120.00
Keyboard/Mouse Logitech MK120 USB wired combo $21.00
Hard Drive #1 Corsair Force GT CSSD-F90GBGT-BK 2.5" 90GB SATA III $140.00
DVD Drive #1 Sony Optiarc AD-7690H-01 slot feed $53.00
"Slimline SATA Female to SATA with LP4 Power Cable Adapter N82E16812200374" $16.00
Monitor Dell 23" $120.00
