Old March 2, 2012, 07:14 PM
Default Where to clip Grounding strap
So something I've been wondering about for a while, is where the best place to clip a grounding strap when working on a PC. Can you clip it to just the case and be fine, or do you have to install the PSU, plug it in to an outlet, then clip to the case? On that note, as long as you're grounded, does it matter if you're standing on carpet as you assemble/work on your rig, as long as it isn't on the carpet/floor?
Old March 2, 2012, 07:35 PM
KaptCrunch's Avatar
electricty travels the shortest distance , if strap on wrist . so the current goes to the band thats grounded
note most use a anti-static mat
always touch case before touching MB
Old March 2, 2012, 07:49 PM
grinder's Avatar
correct LordHood2!
if the PC isnt plugged in, it is not grounded (earthed). My service bench at the office is made if steel and is grounded direcetly to a nearby outlet.
Question about anti static wrist strap BootlegUsher Troubleshooting 26 December 11, 2015 12:28 PM
[Electricians] Grounding living room in old house (for htpc) 0o0 Off Topic 24 May 10, 2010 07:56 PM
Grounding? bumfloss New Builds 16 April 20, 2009 05:21 PM
Grounding HDD necessary? MpG Storage 9 March 22, 2009 10:51 AM
Grounding yourself? fawconpunch Troubleshooting 17 June 29, 2008 06:27 PM
