Old February 25, 2012, 09:33 PM
Default i need help im ordering tonight.
hey guys i need help im ordering my parts tonight its going to be a very cheap system.
parts are listed below:
zotac gtx 465
AMD phenom x4 840
coolermaster 212 evo
Antec eleven hundred
ocz zt 650 w
i this is the part that i need ur help with? im tossing between getting a new motherboared and ram or just getting and ssd cause they are the same price? the mother boared is Gigabyte GA-970A-D3 AMD970 $101 and ram i was wondering will the 1866mhz ripjaw ram for sandy bridge work on this boared cause its a amd ? either way ram is about $55 to $70, or i was thinking of getting a sdd ocz agility 3 120 gb $159.
and will a ocz zt 650 watt be enought to power this system its priece is $109 or the 750 is $125 but im not uprading later ? maybe only a few hdd's
Old February 25, 2012, 09:38 PM
Adzsask's Avatar
Only zotac 465 I could find was $260, and EVGA 480's are selling for the same price right now, I have one and it is powerful to say the least.
Old February 25, 2012, 09:40 PM
i have already got the gtx 465 it cost me 70 dollars and the processor was $100 just the ssd or motherboared and new ram, and wattage of the psu is all im worryed about, thanks
Old February 25, 2012, 09:43 PM
Adzsask's Avatar
Ya, you have room to OC both CPU/GPU I ran a heavily OC'ed i7, 4 HDD,10 fans, 2 burners, lights, SLI 460's and more on an OCZ700 watt for a couple years with no problem.
Old February 25, 2012, 09:45 PM
thats good to hear save a few dollars ont he psu and do you think it would be better getting a new motherboard and ram or a ocz agility 3 120 gb ssd ? but atm the ssd will only be running in sata II
Old February 25, 2012, 09:47 PM
Adzsask's Avatar
I have to say SSD, then pick and choose a nice used motherboard for cheap. I run an OCZ agility 3 and it hasn't done anything wrong to me yet.
Old February 25, 2012, 09:57 PM
yeah i want and ssd but atm it will only be running sata II or i could get a motherboared and ram for the same price as 1 ssd ?
Old February 25, 2012, 10:10 PM
Don't get that PSU, OCZ's are much less reliable than brans like XFX, Corsair, Antec, Seasonic, NZXT Hale.
Old February 26, 2012, 01:29 PM
Couple part choices here
AMD 960T much better then the 840
212+ with dual 76.8 stock coolermaster bladmaster fans(means you need another one)
NZXT Source 210 ELITE case
XFX 650 power supply
Radeon 6870 gpu such as XFX dual fan 6870, or, GTX560Ti much much more powerfull then what you have listed and around the same price.
Gskil Ripjaw ram(dont bother with the 1866 memory one, just go 1600 as its rare you can run it at 1866+ anyways on an AMD system) Gskill ram ending in GBRL,GBXL,GBRM,GBSR etc, basically ripjaw, ripjawx, sniper SE, sniper SE low voltage. 1600 class 9,9,9,24 1.5-1.35v
Agility 3 120 or Cosair force GT or Crucial M4 all very good picks, the Agility is the slowest of them
Old February 26, 2012, 01:58 PM
Adzsask's Avatar
The new ZT series are super stable/reliable and recommended by many actually...P.S. I have had an OCZ modxstream 700 for years and it purrs like a kitten same as day one.
Ordering tonight - new build - sandy bridge elimtl New Builds 19 January 22, 2011 04:15 PM
Ordering for US xghostz Cases 4 June 27, 2010 10:20 AM
A New Rig I'm Ordering Sub New Builds 9 November 21, 2009 06:56 AM
Ordering Tonight....advice? bumfloss New Builds 15 September 18, 2009 12:23 PM
Ordering from PCS.com Sniper Off Topic 9 October 14, 2008 06:23 AM
