Old February 13, 2012, 04:44 PM
jtf2's Avatar
Default 3 pin fan connectors in place of 4 pin molex?
i presently use a couple sunbeam 4 port mini bay bus adapters to route wiring that end in molex connectors.
#1 holds say 1 6 channel fan controller,and a couple other 12 volt molex connectors
#2 holds 2x pumps and a couple 12 volt molex connectors.
i have found these new little wiring adapters,that use 3 pin fan connectors,and they can be powered by either a molex or a 6 pin pci-e connector
my question then is this
are the little 3 pin connectors too weak to use as the end connector on a ddc pump,and as well as a fan controller-again instead of a molex.
wire guage would stay the same,other than the smaller guage coming off the 3 pin itself
i am looking at these little wiring adapters as they are small,and i could straight run from the pci-e connectors on the psu instead of having to add on a molex to said pci-e connector
Okay to run dual GTX 460 cards from PCI and molex connectors at the same time? Linus LinusTechTips Q&A 12 October 11, 2011 03:33 AM
How should I add some extra molex? moufen2 Power Supplies 7 September 29, 2010 07:08 PM
So, were are some of those 3 pin to molex connectors for fans? Z Overlord Air Cooling 10 October 21, 2009 12:13 PM
4 pin molex connector Phobia Off Topic 9 June 2, 2009 12:59 AM
4 molex connectors on one cable Brian Power Supplies 2 October 8, 2008 07:27 AM
