Old February 9, 2012, 02:18 AM
Trial Member
Default first build
i'm looking to build a computer in the month or two i'm looking for some advice on the parts i've picked compatibility and quality. The computer will be used for gaming,internet and media. Processor Intel i7 2600k Motherboard Asus p8z68-v pro gen3 Cpu cooler coolermaster hyper 212 plus Ram Corsair cmz16gx3m4a1600c9 vengeance blue 16gb 4x4gb Hard drive Western digital caviar black 2tb 64mb cache 7200rpm Solid state drive Ocz vertex 3 120gb sata3 6gbps Dvd drive Samsung sh-222al Psu Corsair tx950w Video card Gigabyte radeon hd 7950 windforce Case Coolermaster haf x eatx
Old February 9, 2012, 03:23 PM
All i can tell you is that i have most of those components, even recently ordered the mobo you chose, it's a pretty solid build. Unless you're planning on adding another video card though, you don't need a 950w power supply.
Old February 9, 2012, 05:38 PM
Looks good overall. Given you won't buy for a month or two you should just wait and get a new intel processor (ivy bridge) that should be out around the same time you will be buying. That and if you will only be running the one graphics card you could easily get by on a 650w power supply or an 850w if you plan to add a second video card at a later time.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old February 9, 2012, 06:22 PM
Look like you have done your homework the only thing I would change is the Vertex 3. Vertex 3's have a high failure rate so I can't recommend one, you should check out a Crucial M4 SSD, reliability and speed.
Old February 10, 2012, 05:18 AM
pretty good for mid range..u should wait until new CPU come out.then decide.good luck.
To build, or not to build: that is the question Timid newbe New Builds 5 August 12, 2010 04:33 AM
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
Windows 7 Build 7000 VS Windows XP SP3 Build 2600 Benchmarks Veritas Overclocking, Tweaking and Benchmarking 3 March 3, 2009 01:48 PM
Critique my gaming build build 1080p New Builds 10 January 14, 2009 03:18 PM
