Old February 6, 2012, 07:43 AM
neo678123's Avatar
Smile Pc Build need your opinions
I want to buy this build please give your opinion on it
case: Antec Three Hundred - Midi Tower - noPSU
Ram: Corsair Vengeance - 8GB 1600MHz PC3-12800 (ddr3)
Graphics card: MSI Radeon R6970 Lightning - 2GB - PCI-E
HDD: Samsung 1TB 3.5" SATA-300 7200rpm 32MB
CPU cooler: Scythe Mugen 3 - 120mm All sockets
Motherboard: Gigabyte GA-Z68AP-D3 - Socket 1155 - ATX
CPU: Intel Core i5 2500K 3.3GHz 6MB LGA1155
PSU: Corsair - Gaming GS700 - 700 Wat
Used 4:
Gaming (World of Warcraft, Call of duty, Minecraft)
Video editing
3d animation 3D rendering
multitasking on 2-3 screens
Old February 6, 2012, 09:50 AM
Slik's Avatar
If I were you,I would beef up the PSU. The difference in price between a 700 watt and 1000 watt isn't that much money,when you consider what you get. Also,think of future upgrades etc.
Thermaltake Level 10-i7 3930k @ 4.2ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 1600mhz- Two EVGA Titans SLI - Xonar Phoebus Sound Card-Dell 3008 30" Monitor-Razer Tiamat Headphones-Butt Kicker Gamer-TrackIR 5
Old February 6, 2012, 09:58 AM
dandelioneater's Avatar
for the psu you could upgrade to a corsair AX750 unit. For video card how about a 7950? A little bit more expensive than the 6970, but it is more powerful.
Old February 6, 2012, 10:24 AM
Uberg33k's Avatar
If you're going to be doing 3D rendering and or video editing I'd opt for the 2600k. I do a lot of Photoshop rendering which is nothing compared to lets say 3D Studio Max or Maya. Just my 2 cents.
Old February 6, 2012, 02:08 PM
3d rendering + video editing? Def get the 2600k.
PSU is o.k. but I would recommend corsair ax850 watt for any upgrades, and it runs really really cool (fan won't prob turn on for that load).
Old February 6, 2012, 03:05 PM
Lsv's Avatar
Lsv Lsv is offline
Unless OP will OC and put a second card in there an 850w PSU will be overkill.
i7 920 (no oc) w/ Noctua NH-D14
Asus P6T
Asus 6950 DC II 2gb
12gb G.Skill Ripjaws 1600mhz
Intel X-25M 80gb Gen2
2x WD Caviar Green 1TB 64m cache
2x WD Caviar Green 2TB 64m cache
Native Instruments Komplete Audio 6
Seasonic X-660
Fractal Design R3 + 4x Noctua S12B 120mm
Old February 6, 2012, 04:04 PM
He's right. I mean only get an 850ax instead of the 750 watt (which is more than enough) if you plan on OC+crossfire.
Old February 7, 2012, 09:05 AM
neo678123's Avatar
I think I'll just take the gs800 and 6970 But I think i will upgrade to the 2600k so it can run for a few years
Need your opinions on this WC-Build Closed Note Water Cooling 3 August 13, 2010 02:14 AM
Opinions on this build? squilliam New Builds 4 May 8, 2010 01:28 PM
Build Opinions icecoals New Builds 45 May 6, 2010 04:12 PM
New Build need opinions FrankyG New Builds 11 September 22, 2008 10:00 AM
Opinions on build? MarX New Builds 7 August 28, 2008 04:00 PM
