Originally Posted by Silent_Avenger Stick with the well known brands even though they cost more they save you a lot in the long run. Corsair, seasonic, Antec, XFX are all good brands. |
Thanks for the recommendation. I'll switch over to an XFX 650 watts, its got some good reviews, the newegg vid review sold me.
Originally Posted by chrisk Do you have any parts from a current rig you can reuse? I am thinking a DVD drive, hard drive, Windows 7 license, etc.
Also, you mentioned a 2500K cpu...the K cpus are meant to easily overclock; will you be overclocking? If not, maybe some money could be saved there. |
I'm currently on my Laptop from 2004, which I'm really in need to upgrade from, so nope no extra parts unfortunately (well windows xp which I actually dont mind as an OS). but its not like I'm trying to save every penny I can. Its just my first build so I do want a good reasonably priced rig, and if I really enjoy it then I'll start dishing out for the top of the line, plus it'll be easier to when I'm no longer a student and working full time.
As for the unlocked CPU, I read that a good recommendation for playing skyrim is at least 3.3GHz to get the most out of it, and the unlocked i5 is only a few bucks up from the locked one on Directcanada, so wouldn't it be better to have the option to unlock it if I feel the need to down the road? and if not I still have a pretty good processor.
Originally Posted by sswilson If it were me, and that's all the money you can/want to spend right now, I'd be inclined to pick up the ACER with the thought of stripping out the parts at a later date for a proper custom build.
edit: It's also worth mentioning that the HDDs are 5400 RPM drives. Pretty slow in this day and age. |
Originally Posted by sswilson The general rule has always seemed to be that a person could build a system for around the same price as the big box retailers, but it wouldn't include an OS |
I've kinda wanted to do a build since I was 12 so I'm sticking with it for the novelty/learning factor as well as having a high performing PC. and if I ended up buying the Asus I know I'll end up putting off building one for years, and the case I already ordered and all my researching parts would be for waste.
As for the OS, I might go with Linux mint or Ubuntu and use an old xp I have for games until windows 8 comes out.
heres the build I've got in mind so far:
-CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model
Newegg.ca - CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9
-Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Newegg.ca - Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
-Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost)
Newegg.ca - Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
-LITE-ON DVD Burner
Newegg.ca - LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 - CD / DVD Burners
-GIGABYTE GA-Z68X-UD3H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Newegg.ca - GIGABYTE GA-Z68X-UD3H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
-SAPPHIRE 100315L Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity.
Newegg.ca - SAPPHIRE 100315L Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
From what I take from this, it's well priced for all its features, not the most powerful, but I should be able to do multiple screens, and the option to have 3dhd up to my tv, or 3d gaming if I'm if thats what I'm interpreting correctly from the write up. Though not sure if I will do 3d, but having the option is nice.
-XFX Core Edition PRO650W (P1-650S-NLB9) 650W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified.
Newegg.ca - XFX Core Edition PRO650W (P1-650S-NLB9) 650W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
Then I'll eventually like to add these in.
-OCZ Agility Series OCZSSD2-1AGT30G 2.5" 30GB SATA II MLC Internal Solid State Drive (SSD)
Newegg.ca - OCZ Agility Series OCZSSD2-1AGT30G 2.5" 30GB SATA II MLC Internal Solid State Drive (SSD)
-Koutech IO-RCM630 Multi-in-1 USB 3.0 SuperSpeed Front Panel Internal Card Reader with USB 3.0 Port (3.5")
Newegg.ca - Koutech IO-RCM630 Multi-in-1 USB 3.0 SuperSpeed Front Panel Internal Card Reader with USB 3.0 Port (3.5")
-Seagate Barracuda XT ST32000641AS 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Newegg.ca - Seagate Barracuda XT ST32000641AS 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
So over all I'm only a bit over.
thanks for the feedback, you guys a great saving me alot of guess work and confusion.
