Old February 3, 2012, 10:35 AM
Default PC Build (3 monitors)
Hi,
I'm new to the custom pc world but I need to build my own in order to cope with my work requirment and I was hoping that you can help. I'm stock analyst and a project manager.
I need 3 27" monitors capable of HD 1080p connected to one pc.
I'm not sure about the rest of the parts needed to build my pc. Which case to go with? processor? other part?
I'm really not an expert about this and I'm looking for your help.
Thank you.
Old February 3, 2012, 04:44 PM
Well, any current gen AMD card can do tri monitor without much of an issue, and you do not need the highest end ones to do this.
A decent card for this would be Newegg.ca - SAPPHIRE Flex 100328FLEX Radeon HD 6770 1GB GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card this way here you do not need any fancy extra connectors or whatever, in AMD world this is called Eyefinity, it allows multiple monitors to be fed from a single graphics card, you generally need to run 1 monitor off of display port 1 off of HDMI and another off of VGA/DVI, so there are quite a few options here, but I would go AMD in this regard or possibly a Galaxy MDT card, the cheapest that I can see being this one
Newegg.ca - Galaxy 21GGE4AM9EKP MDT X4 GeForce 210 Multi Display 1GB 64-bit DDR2 PCI Express 2.0 x16 HDCP Ready Video Card now you said 1080p, so I would probably go with Radeon 6770 or higher 6850/6870 etc, but the 6770 should do this fine.
I am not used to doing low cost builds, however, i3 2120 might be a good cpu or AMD Athlon II x4 such as Newegg.ca - AMD Athlon II X4 645 Propus 3.1GHz Socket AM3 95W Quad-Core Desktop Processor ADX645WFGMBOX
a good motherboard that will work well for your needs ASUS M5A97 Newegg.com - ASUS M5A97 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
a good power supply Newegg.com - XFX Core Edition PRO550W (P1-550S-XXB9) 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply 550w should be more then enough for your needs at least for a "mid to high range" single graphics card
Memory any one of these Newegg.com - Computer Hardware, Memory, Desktop Memory, 8GB (2 x 4GB), 1.5V, 9, Gskill DDR3
a good but low cost case Newegg.com - NZXT M59 - 001BK Black Steel ATX Mid Tower Computer Case
and of course hard drives/optical drives, keyboard, mouse etc
hard drives tend to range between $65-$180+ for a single drive, if you do not have that much to store/use you could also go with a Solid state drive instead
Newegg.com - Internal Hard Drives
or SSD 60Gb or larger, SSD are very very fast but more expensive for thier size, if you have 2 hard drives, one SSD being for your operating system, and the other being used for storage you get the best of both worlds, but obviously is a larger cost
OCZ Agility 3, Crucial M4, and Corsair Force GT, are all very good, very fast, and resonable cost SSD.
For a Standard Hard drive, western Digital Caviar Blue or Caviar Black, the caviar blacks are faster and with a longer warranty, but for non gaming use, the caviar blue should work fine
Any key board will work fine, we all have our own tastes, for a mouse, Logitech MX518 or Coolermaster Inferno are good picks, and very adjustable while not being to expensive.
Old February 3, 2012, 07:55 PM
Thank you for all the details
I'm looking for a high end PC. Please advise
Can I order the hardware from your website?
Thanks
Old February 3, 2012, 10:14 PM
dandelioneater's Avatar
Thanks
I'm not sure if you mean if u can buy from this site (HWC?) but no HWC isn't a retailer.
Try NCIX, or newegg, etc.
How much are u looking to spend?, what are you using the machine for? (games, video editing, etc,), we need more info to suggest a build that would be suitably for your needs
PLEASE when POST threads asking for input on system builds tell us...
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
9. What resolution do you use?
Old February 4, 2012, 06:46 AM
Dzzope's Avatar
look at NCIX or other preferable retailer.. (ncix with price-match is a favourite here)
i5 2500k (lets you over clock and not much price difference)
Cooler master 212 + (cheap and good cooler for your cpu)
z68 motherboard (abit gigabyte etc all pretty good, get mid range for a solid but not over the top board)
2x4GB ram (anything at all really in ddr3)
ati 6850 GPU for 3 monitors..
SSD get a 120GB or 256 depending on budget (install your OS and programs here)
HDD.. depends on how much data you store... get any that is large enough.. Seagate Barracuda 3TB is brilliant but may be more than you need
PSU.. any 650 watt seasonic, antec, corsair, xfx one will do and be very solid
Case, any ATX compatible one you like the look of.. is sound an issue?
For the monitors, you may need adapters if they don't take a display-port.. you need to work this out..
Old February 4, 2012, 08:46 AM
Thank you for your help.
The purpose of the PC is stock analyst and project managment. I'm looking for high-end quality hardware.
Old February 4, 2012, 08:50 AM
1. What YOUR PC will be used for. That means what types of tasks you'll be performing. Stock analysis and projects management.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread. I'm looking for a high end hardware. $5,000
3. What country YOU will be buying YOUR parts from. US or Canada
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture. I don't have a brand preference.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are. No, I'm not.
6. IF YOU have searched and/or read similar threads. I didn't.
7. IF YOU plan on overclocking or run the system at default speeds. What do you mean?
8. WHEN do you plan to build it? within a month.
9. What resolution do you use? HD
Thank you
Old February 4, 2012, 10:40 PM
Dzzope's Avatar
Just as a slightly over the top example I did the following on NCIX (so price is CA dollars)they are well beyond your needs.. but may be what your looking for..
Really $2500 would be plenty of a budget.. note that these are not including monitors or mouse - keyboard etc (but do have a triple stand for the monitors, which I just noticed are bigger than it can take.. so remove.. :D))
2 of Processors (CPUs) Intel Xeon E5506 Quad Core 2.13GHZ LGA1366 4MB 4.8GT/SEC Nehalem Retail Processor 2 $462.41
CPU Heatsinks Supermicro SNK-P0040AP4 Active CPU Heatsink for Xeon 5500 LGA1366 Scocket 2 $60.91
Motherboards Supermicro X8DTI-F Xeon 2XLGA1366 Intel 5520 DDR3 ECC 6SATA 4PCIE 2PCI 2GBLAN IPMI EATX 1 $398.91
DDR3 Server Memory Kingston ValueRAM KVR1333D3E9SK3/12G 12GB 3X4GB PC3-10600 DDR3-1333 CL9 ECC DIMM Memory Kit 2 $358.19
(may need 2) Workstation Video Cards NVIDIA Quadro 2000 by PNY 1.0GB GDDR5 PCI-E16 DVI 2x Display Port Fermi Workstation Video Card 1 $464.51
Computer Cases Fractal Design Define XL Titanium E-ATX Mid Tower Silent Computer Case 4X5.25 10X3.5INT No PS 1 $159.99
Power Supplies Corsair Professional Series Gold AX850 CMPSU-850AX 850W ATX Fully Modular 80PLUS Gold Power Supply 1 $199.99
Monitor Accessories XFX Fxtristand Triple LCD Display Monitor Stand - Supports 3 LCD Monitors From 17IN to 24IN Each 1 $379.99
Operating Systems Microsoft Windows 7 Ultimate Edition 64BIT DVD SP1 OEM 1 $209.98
Hard Drives Western Digital WD Caviar Blue 1TB SATA 6GB/S 7200RPM 32MB Cache 3.5IN Hard Drive OEM 2 $219.98
Solid State Drives - SSD Intel 320 Series GEN3 300GB 2.5IN SSD SATA2 Solid State Disk Flash Drive OEM 1 $595.33
CD & DVD Drives LG GH22NS70 Super Multi 22X SATA DVD Writer Black OEM 1 $21.02
Blu-Ray Drives LG BH12LS35 Blu-Ray Writer 12X BD-R 16X DVD+R Lightscribe 3D Ready SATA 1 $129.99
Flash Card Readers nGear Flash Card Reader 3.5IN Internal USB Black CF/SM/SDHC/MMC/MS/XD 18IN Cable 1 $18.99
Sound Cards Please Use The Onboard Sound Card Integrated On My Motherboard 1 $0.56
Network Adapters Please Use The Onboard Network Ethernet Card Integrated On My Motherboard 1 $0.56
Assembly Options PC Assembly and Testing With 1 Year Limited NCIX System Warranty (PRE-CONFIG WIN. OS If Purchased)
PC Assembly & Testing does not include servers and requires an additional 4-5 business days to ship once all parts are in stock. NCIX will install aftermarket heatsinks or pre-filled CPU liquid coolers. 1 Year Limited Warranty on installed system parts. 1 $45.19
Warranty Options Standard 1 Year Limited Warranty With NCIX IN-HOUSE Tech Support
Please note that Extended Service plans with On-Site service are available for your system at check-out. 1 $0.56
UPS/Power Management OPTI-UPS GS1100B 1100VA 550W AVR Step Wave RJ11/RJ45 USB 6 Outlet
$5.00 mail in rebate, valid from Feb 01, 2012 to Feb 29, 2012
Rebate Form: http://source.ncix.com/pdf/http://ww...ncix-exclusive 1 $110.69
Your Price:
$3,837.76
Configuration Detail (3928746) @ Feb 04, 2012
Category Description Quantity Price
Video Cards Galaxy Mdt GeForce GTX 560 830MHZ 1280MB 4GHZ DDR5 3x DVI-D 1XDVI-I 1x Mini-HDMI PCI-E Video Card 2 $457.68
Processors (CPUs) Intel Core i7 3930K 6 Core 12MB 3.2GHZ Hyperthreading Unlocked LGA2011 Processor No HSF 1 $655.98
CPU Heatsinks Intel RTS2011LC CPU Liquid Cooling System 150MM Radiator 120MM 74CFM 35DBA LGA2011 LGA1155 1156 1366 1 $89.99
Motherboards ASUS P9X79 WS ATX LGA2011 X79 DDR3 6PCI-E16 SATA3 USB3.0 SLI CrossFireX Audio Motherboard 1 $412.45
DDR3 Desktop Memory Corsair CMZ16GX3M4A1600C9 Vengeance 16GB 4X4GB DDR3-1600 CL9-9-9-24 Dual Channel Memory Kit 1 $104.30
Computer Cases Fractal Design Define R3 Titanium ATX Mid Tower Silent Computer Case 2X5.25 8X3.5INT USB3.0 No PS 1 $114.99
Power Supplies Seasonic X850 Gold ATX 12V 24PIN 850W Active PFC 80PLUS Gold Modular SLI Ready Power Supply 1 $219.02
Hard Drives Seagate Barracuda 3TB 7200RPM SATA3 64MB Cache 3.5IN Internal Hard Drive
$20.00 instant discount, valid from Feb 01, 2012 to Feb 29, 2012 2 $479.96
Solid State Drives - SSD Intel 510 Series 120GB Solid State Drive SSD 2.5IN SATA 6GB/S Elm Crest 1 $322.18
Network Adapters Please Use The Onboard Network Ethernet Card Integrated On My Motherboard 1 $0.98
PC Assembly & Testing does not include servers and requires an additional 4-5 business days to ship once all parts are in stock. NCIX will install aftermarket heatsinks or pre-filled CPU liquid coolers. 1 Year Limited Warranty on installed system parts. 1 $49.61
Please note that Extended Service plans with On-Site service are available for your system at check-out. 1 $0.95
Reg. Price:
$3,687.04
Instant Discount:
-$40.00
Your Price:
$3,647.04
Old February 5, 2012, 08:54 AM
Thank you.
Old February 5, 2012, 09:12 AM
neo678123's Avatar
I would go for an i7 2600k, 8GB+ RAM, A GFX card with 2gb+ (6970, 6990, GTX580, GTX590, 7970, 7950)
Build for 3 Monitors, XFX Triple Stand RM - Ottawa New Builds 22 November 13, 2011 09:23 AM
What monitors to get? SKW Display Units 8 August 1, 2011 03:28 PM
2 monitors, what to do muse108dc Display Units 3 May 26, 2011 08:13 PM
cheap USB Monitors BobbyLou Display Units 0 May 31, 2010 10:24 PM
2 Monitors ih8purple Display Units 3 January 23, 2008 12:09 AM
