Old February 5, 2012, 09:40 AM
Why you choose that one?
Old February 5, 2012, 10:16 AM
Adzsask's Avatar
Originally Posted by neo678123 View Post
I would go for an i7 2600k, 8GB+ RAM, A GFX card with 2gb+ (6970, 6990, GTX580, GTX590, 7970, 7950)
You are referring him to graphics cards that only support 2 monitors... that's why people were pointing him towards the galaxy multi display cards. The cards you pointed out should be recommended to a mid/high end gamer that is using either 1 monitor, or 2.
Old February 5, 2012, 12:02 PM
Supergrover's Avatar
Hmmm I have 6 outputs on my 6970's and you dont get much higher end than a 7970 right now so I am kinda stumped on that comment.
High end GFX and monitors I would go 3xu2711's and either a single 7970 ( your not going to game just office so 1 should be fine for that pixel density)
A 2600/2700 cpu should be more than enough as would 8gb (16gb if you feel the need )of ddr-1600, no need for a multi/cpu solution here it is just going to be office apps , now if you were doing any video editing then yes I could see a multi setup.
A platinum 850-1000w psu Seasonic, XFX, corsair
Since it is a office build I would look for a case that matches either the decor or with the smallest cleanest footprint..
Drop a 256gb SSD for OS and a 4x raid1-0 setup using the largest hdd's you feel comfortable with.
R.I.P.
Old February 5, 2012, 12:52 PM
Thanks for your help. What do you recommend for a case?
Old February 5, 2012, 01:07 PM
Depends on your tastes, are you someone that wants flash or simple lines?
Do you care what size the case is?
If flashy what colors?
Lights? Windows?
Myself I like no bling, bling/ no windows/ no lights, just simple forms in black. Brushed ALU is about my favorite.
But then again some ppl dont go for that and want the opposite.
R.I.P.
Old February 5, 2012, 07:07 PM
Thanks
Old February 5, 2012, 09:30 PM
Thanks
Lian Li Industrial Co., Ltd.
Lillys make damn fine cases.
R.I.P.
Old February 6, 2012, 08:44 AM
Dzzope's Avatar
Silent case would be good.. though this is again personal preference..
The one I listed in the 2 spec's is simple lines, good quality and insulated for sound.
Not my favourite looking case but quite professional looking.
  #19 (permalink)
Old February 6, 2012, 08:45 AM
Dzzope's Avatar
I believe he was talking about the nvidia's.. the ones you listed (580 etc) won't support 3 monitors with 1 card.
Ps, i did say the builds I listed were OTT for his needs but still came in well under budget (assuming he has the monitors)
on the monitors, the dell u27's are great.. also worth considering (if you want to go for a monitor with a higher resolution than HD, would be good to try before you buy) is the Samsung SyncMaster 27A850D
Try these resolutions and size combo's before you buy as they are not cheap but are VERY good.
  #20 (permalink)
Old February 6, 2012, 09:19 AM
Painbringer71's Avatar
Don't forget the the special cable needed for the third monitor. Mini DP to (DVI or HDMI or even VGA whatever one you need for your set up) And yes it has to be active 20-30 Dollars US or so
Check your video cards out puts first and remember the HDMI and one of the DVI outputs share the same port so you can not use both at the same time its a one or the other. (this is for the ATI cards)
Build for 3 Monitors, XFX Triple Stand RM - Ottawa New Builds 22 November 13, 2011 09:23 AM
What monitors to get? SKW Display Units 8 August 1, 2011 03:28 PM
2 monitors, what to do muse108dc Display Units 3 May 26, 2011 08:13 PM
cheap USB Monitors BobbyLou Display Units 0 May 31, 2010 10:24 PM
2 Monitors ih8purple Display Units 3 January 23, 2008 12:09 AM
