Old January 25, 2012, 12:47 AM
Default My First Rig! Compatibly?
Hello i am about to purchase my first rig and i would just like to make sure that everything is going to work together properly I put everything i plan on buying in my specs someone please confirm this before i purchase. Thanks!
Old January 25, 2012, 12:52 AM
supaflyx3's Avatar
Would be helpful if you posted what you're planning on buying..
Old January 25, 2012, 12:54 AM
Supergrover's Avatar
As he stated in his Specs, check the dropdown.
Not a fan of rosewell PSU's
R.I.P.
Old January 25, 2012, 03:16 AM
Apathetik's Avatar
Yeah I would go with a Thermaltake or Coolermaster PSU for around the same price over a Rosewell one. Other then that, everything else looks great!
Old January 25, 2012, 03:48 AM
some rosewell psu's are good as far as I read because some of them use superflower psu's
but that one, i have no idea who made it, I could be wrong though.
thermaltake/corsair/xfx/coolermaster are great choices
Old January 25, 2012, 04:05 AM
supaflyx3's Avatar
oh, well in that case.
Get a Phenom II 955, with the saved money you can probably upgrade to 8GB of ram. Aside from the PSU, everything looks fine. But if you can afford it go for a 560ti over a 560.
Old January 25, 2012, 04:09 AM
Avenger212's Avatar
Coolermaster and Thermaltake PSU are not very good. These PSU can put your PC at risk. But the other brands from the above statements are really good.
Old January 25, 2012, 04:44 AM
Yup Antec make some good lower wattage cheaper units also if moneys are tight.
But yeah Seasonic, corsair, the newer xfx. Stay away from CM's, TT, ocz.
R.I.P.
